Local Time 18:48 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LS 20031 GPS from Sparkfun
Herry
Posted: 06:17am 19 Mar 2016
Has anyone successfully used the Sparkfun GPS unit with built in aerial, known as the LS 20031? Were there any problems with its update rate of 5 per second? Also any hardware tips (it doesn't come with a connector. You have to solder on a right angle header). Does the normal code work with it?
Senior?!  Whatever it says, I'm a complete and utter beginner...
MM_Wombat
Posted: 11:05am 19 Mar 2016
All should work ok. The datasheet indicates the default speed is 1Hz and baudrate is 9600.
GPS Pin 5 (left-most when viewed from above) : No connection (or ground)
GPS Pin 4 : to Micromite ground (GND) pin
GPS Pin 3 : to Micromite Com1 Rx pin
GPS Pin 2 : No connection
GPS Pin 1 (right-most when viewed from above) : to Micromite 3.3V pin
The arduino had problems because the recieve buffer was too small, but the Micromites buffer is 256 characters.
I have the U-blox Neo-6M working fine @ 9600 baud
MM_Wombat
Maximite, ColourMaximite, MM+
Herry
Posted: 02:01pm 24 Apr 2016
I am not having much luck with this. With the Sparkfun Venus, I have a project working fine, Baud rate 9600.
With the LS 20031, the project does not work and the whole program locks up. I have the power to the LS 20031 OK and it blinks when it has acquired the satellites, but the prog locks up as soon as I connect the TX. Anyone actually used this device successfully?
srnet
Posted: 07:27pm 24 Apr 2016
  MM_Wombat said  The arduino had problems because the recieve buffer was too small, but the Micromites buffer is 256 characters.
MM_Wombat
Interesting, I have been using the Ublox7, Ublox8 as well as a couple of other 9600 GPS with softserial on a 8Mhz Pro Mini, no problems.
There is one issue with the TinyGPS++ library and the Ublox, you have to check that the altitude has updated before using the fix.
There is GPS code for my LoRa lost model locator here;
https://goo.gl/IeEiC1
Herry
Posted: 10:03am 26 Apr 2016
Still no luck. I note the LS20031 is a TTL device, so presumably that is not the problem, and it can be interfaced directly with the Micromite? The project works perfectly with the Sparkfun Venus. The mystery is why is hangs the whole program.Edited by Herry 2016-04-27
Justplayin
Posted: 11:02am 26 Apr 2016
I believe the above information is incorrect. From the data sheet:
LS20031
Pin #....Name....Type...Description
1........VCC.....P......Power input
2........RX......I......Data input (TTL level)
3........TX......O......Data output (TTL level)
4........GND.....P......Ground
So, the Micromite TX line would connect to pin 2 of the LS20031 and the Micromite RX line attached to pin 3 of the LS20031.
--Curtis
Herry
Posted: 11:17am 26 Apr 2016
I don't think the connections are the problem. My LS20031 shows a blinking light correctly when it has sufficient acquisitions. And I see no reason to connect the LS20031 RX line. As we only need to read the NMEA sentences, the TX line should be enough, shouldn't it?
However, I'm puzzled by the baud rate. The data sheet shows 9600, but much material about this unit with the Arduino (where it is being used by many) seems to strongly favour 57600.Edited by Herry 2016-04-27
Bizzie
Posted: 11:35am 26 Apr 2016
Do you get the data when the GPS is connected to a USB serial converter and you run TeraTerm on your PC?
Rob White
Justplayin
Posted: 11:38am 26 Apr 2016
  Herry said  However, I'm puzzled by the baud rate. The data sheet shows 9600, but much material about this unit with the Arduino (where it is being used by many) seems to strongly favour 57600.
I noticed 57600 reference too, but the docs clearly indicates 9600. I would take a USB to TTL adapter and connect it directly to the module. Then using Tera Term (or similar) step through the various baud rates until you see good data.
--Curtis
