Local Time 15:15 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Edit - GOSUB without line numbers
larny
Posted: 06:44pm 18 Mar 2016
I recently installed the latest firmware in my Maximite & the latest version of MM Edit.
I like not having to use line numbers, but I cannot find out how to insert labels for GOTO & GOSUB.
I searched in the MMedit.pdf & the MMedit Help but all I could find (of course it may be staring me in the face) was the following.
"With MM Edit you can convert code that has line numbers to code with labels"
I was able to convert the code I had written with line numbers to code with labels, but now I want to add another sub routine. I cannot see how to insert a label for the GOSUB.
It is easy to do it for PIC programmes in the Microchip MPLAB IDE using assembly code, but I can't see how to do it in MMEdit.
Any assistance will be appreciated.
centrex
Posted: 07:30pm 18 Mar 2016
Gosub test1
Somewhere else you have
Test1:
Followed by
Return
Cliff
Posted: 09:35pm 18 Mar 2016
Best way forward is to use defined subroutines and functions.
Using labels for subroutines is not preferred.
Try to code without the use of GOTO, only when it will be more clear what the code is doing. Not jump around!
[code]
SayHello
PRINT "5 squared = " SquareIt(5)
SUB SayHello
PRINT 'Hello from MySubroutine'
END SUB
FUNCTION SquareIt(value)
SquareIt = value * value
END FUNCTION
[/code]
Edited by MicroBlocks 2016-03-20
larny
Posted: 05:32pm 19 Mar 2016
  centrex said   Gosub test1
Test1:
Followed by
Return
Thanks Cliff,
So it is essentially that same as assembly in MPLAB.
larny
Posted: 05:34pm 19 Mar 2016
  MicroBlocks said   Best way forward is to use defined subroutines and functions.
[code]
SayHello
SUB SayHello
END SUB
END FUNCTION
[/code]
Thanks for that info, I'll try it.
