Local Time 15:16 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : bitcopy
drkl
Posted: 12:30am 17 Mar 2016
Hello,
How can realize the bitcopy instruction in MMBasic?
REG2.BIT2=REG1.BIT1
REG1,REG2 are a 8 or 16 bit integers
BIT1,BIT2 are the bit positions within the integers.
drkl
jwaldha
Posted: 01:39am 17 Mar 2016
Quick and dirty:
Sub bc(reg1 As integer, bit1 As integer, reg2 As integer, bit2 As integer)
Print "before: "; Bin$(reg1), bit1, Bin$(reg2), bit2
If (reg1 And (2 ^ bit1)) Then
reg2 = reg2 Or (2 ^ bit2)
Else
reg2 = reg2 And ((2 ^ bit2) Xor &hffffffffffffffff)
Print "after : "; Bin$(reg1), bit1, Bin$(reg2), bit2
JWaldha
drkl
Posted: 06:55am 17 Mar 2016
Hello,
The world is small, isn't it? All is hungarian...
Thank you for your code snipet, it is very good, I tested.
I try to use masking, but it was too difficult...
If you think,look: http://drkonya.eu
drkl
