Local Time 11:03 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : help with subroutine
crez
Posted: 09:13pm 03 Mar 2016
I wish to call a subroutine like:
this_sub(1,2,3)
or this_sub(22,67,5,42)
and have this_sub allocate the n arguments to the first n elements of a local integer array. I feel there is a simple way of doing this but I have not found it. I'm probably having a brain fade . Can anyone help?
Posted: 09:41pm 03 Mar 2016
Probably not possible as almost all Basics disallow variable numbers of arguments.
Posted: 10:02pm 03 Mar 2016
  Quote   wish to call a subroutine like:
this_sub(1,2,3)
This works fine. non-included arguments are set to 0 in the subroutine. The only gotcha is if 0 needs to be a valid parameter.
test 1,2,3
end
sub test(a%,b%,c%,d%)
print a%,b%,c%,d%
end sub
prints "1 2 3 0"
crez
Posted: 10:49pm 03 Mar 2016
that works, but now for allocating the values to elements of an array, without
arr(1)=a% : arr(2)=b% : arr(3)=c% etc. It gets a bit untidy if I have a maximum of say 25 values.
Posted: 06:21am 04 Mar 2016
It is rare to want to write code like that in Basic. Your best bet is to use a different way.
crez
Posted: 11:36am 04 Mar 2016
John,
I guess you are right, the main reason I am trying this way is because I am translating some C code to basic. The C code uses pointers, which don't have a direct translation in basic. I was hoping I was missing something obvious which someone would point out to me.
The following code does what I wanted but relies on the local variables a-f being in sequence in memory. Perhaps there is a chance that an interrupt happening during the opening of the sub would mean this is not so.
'a% is the number of following arguments
' all arguments are 0-255 integers
Sub writeBuf(a%,b%,c%,d%,e%,f%)
Local integer z,cnt,v
cnt=Peek(var a%,0)
For z=1 To cnt
arr(z)=Peek(var a%,z*64)
Next z
