Local Time 11:02 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite LCD backpack
Herry
Posted: 09:46am 27 Feb 2016
I am building this unit featured in Silicon Chip February 2016, using the SC kit. The two 100 nf ceramics are OK, but the two 10 mfd (at the regulator)and one 47 mfd (on pin 20) capacitors are shown with polarity on the PCB, but on the tiny SMD capacitors supplied, no polarity marks appear to be visible.
Senior?!  Whatever it says, I'm a complete and utter beginner...
palcal
Posted: 11:43am 27 Feb 2016
Hi Herry,
The caps should have a stripe across one end, sometimes it is hard to
see, the stripe end is +
Paul.
Herry
Posted: 12:52pm 27 Feb 2016
  palcal said   Hi Herry,
Paul.
Thanks for the reply, but there is quite definitely no stripe. On the other hand the text mentions that multilayer ceramics may be supplied if SMDs and of course these are not polarised. Further thoughts from anyone??
twofingers
Posted: 03:22pm 27 Feb 2016
Hi Herry,
maybe (!) this are ceramics and you don't need to care about polarity.
I'm confident of that! Just try!
Michael
Posted: 06:00pm 27 Feb 2016
Hi Herry,
I would assume (I know I shouldnt do that) that these are most likely ceramic which do not need to be polarised..
Generally Polarised Caps are Tantalum and these are mostly YELLOW or BLACK in colour but the case is always some sort of plastic. If they are Ceramics these are generally a Brown to greyish colour and not plastic but the ceramic itself.
If unsure try to post a clear picture up on TBS and we will check for you.
Kind Regards,
disco4now
Posted: 06:01pm 27 Feb 2016
Note from Silicon Chip article.
  Quote  Note that the 10uF and 47uF capacitors are polarised. (the longer lead is the positive)
Gerry
Cancel that, I see you have SMD , no legs!Edited by disco4now 2016-02-29
F4 H7FotSF4xGT
Herry
Posted: 05:14pm 29 Feb 2016
Thanks all. I thought I had set the notifications to 'email me' but apparently not. Have just seen these. Unit working AOK.
