Local Time 10:06 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Quick CS question...
Posted: 12:10am 22 Feb 2016
With SPI devices, is it correct to assume that all CS lines are the same in that they are normally tied HIGH, and pulled LOW when selected by the MCU - correct?
In my case, I have a few spare 2.4" LCD's with touch. I want to permanently select the LCD, and permanently disable the touch.
With that in mind, my brain is suggesting that to do this, I would connect the LCD CS to ground permanently, and the touch CS high permanently. This would enable the LCD, and permanently disable the touch controller - yes?
Just need to make sure I am understanding this correctly, as the MM normally handles the CS pins for me.
Frank N. Furter
Posted: 12:17am 22 Feb 2016
Hi Grogster,
that should be ok! CS is normally low active and you are right!
Frank
