Local Time 10:06 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Convert Arduino code to Micromite Basic
lew247
Posted: 04:24am 13 Feb 2016
Is there anyone here that is able to convert Arduino code to MM Basic?
I want to use a BME280 module, there are a couple of example codes/sketches for the Arduino but I can't find any for the Micromite.
And I can't find any examples of MMBasic for the BME280 module.
My knowledge of basic is way too weak to even consider anything myself unfortunately.
MM_Wombat
Posted: 08:28pm 14 Feb 2016
@lew247
I could give it a go, but I would have to buy the module first, and wait for it to arrive. I could attempt to write the code, but debugging would be difficult if I didn't have the module. Little Bird Electronics have it for 30 AUD, in Sydney.
I did the same thing for the DMD Panels from freetronics a while back..
Which version of the Micromite would it be for. I have the MM+ from CircuitGizmo.
I also have the Arduino Eleven from Freetronics for comparisons.
MM_WombatEdited by MM_Wombat 2016-02-16
Maximite, ColourMaximite, MM+
palcal
Posted: 08:59pm 14 Feb 2016
In the adafruit datasheet on page 23 there is code that appears to be written in C
(I'm all at sea with C I'm afraid}. Maybe this could be used as a C function, maybe one of the C gurus could answer but you still have to extract the calibration data from the device and I'm sure someone here could do that.
Paul.
atmega8
Posted: 10:02pm 14 Feb 2016
This Code is in Bascom, a Basic Language for AVR Controllers.
IT should be easy to Converter to mmbasic.
http://www.mikrocontroller.net/attachment/280969/BME280.bas
Posted: 12:26am 15 Feb 2016
  MM_Wombat said   debugging would be difficult if I didn't have the module. Little Bird Electronics have it for 30 AUD, in Sydney.
MM_Wombat
try here for a somewhat better price:
http://www.ebay.com/itm/321988583888
(BMP280, less than us$2 including delivery)
http://www.ebay.com/itm/401000227934
(BME280, less than us$6 including delivery)
rob :-)
Edited by robert.rozee 2016-02-16
Posted: 01:21am 15 Feb 2016
  Quote  Is there anyone here that is able to convert Arduino code to MM Basic?
If you send me the module I'll get it working for you. Send me a PM if interested
lew247
Posted: 03:52am 15 Feb 2016
Sent you a pm matherp
MM_Wombat
Posted: 09:12pm 15 Feb 2016
@lew247
See, someone answers , then all the offers come in. I'm sure Matherp would do a better job than me anyway.
MM_Wombat
TassieRosco
Posted: 03:32pm 16 Feb 2016
I put the BME280.bas BASCOM file through Google Translate for the english speakers. See:
2016-02-17_013037_BME280_en.pdf
  atmega8 said   This Code is in Bascom, a Basic Language for AVR Controllers.
bigfix
Posted: 10:48pm 17 Feb 2016
I just stepped over this guide :
Convert Arduino Code to MPLAB IDE
It explains briefly how to port Arduino code to PIC
I guess it could be useful to try Arduino supported HW on a PIC32 System
It will run standalone - not integrate with MMbasic
I do not speak "C", so cannot judge about it...
- maybe helpful Edited by bigfix 2016-02-19
