Local Time 09:10 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help using touch screen
Benzol
Posted: 04:15pm 10 Feb 2016
Hi everyone
I am having trouble working out how to use the LCD touch screen. I would like to turn on a relay for lighting when i touch a circle on the screen. There will be four circles for 4 different lighting circuits. Then turn off the relay(s) when the circle is touched again.
I just can't figure out the code.
Can anybody out there point me in the right direction please.
Regards db
Posted: 04:33pm 10 Feb 2016
Hi-de-hi.
As far as I know, circular buttons are not supported.
Square or rectangular ones are, but circular ones are not.
You could use a radio-button box to select the lamp you wanted, and as each radio-button was selected, it would automatically turn the others off. Only one could be on at any one time though, and that might not suit.
You can make the radio-buttons any size you like though.
Our Cfunction gurus might be able to write something to generate circular buttons.
EDIT: Oh, BTW - Standard MM2 or MM+?Edited by Grogster 2016-02-12
Benzol
Posted: 04:45pm 10 Feb 2016
Hi Grogster
I'm using the standard micromite II V5.1 as per the backpack in Silicon Chip. Drawing the circles is easy enough, I figured it would 'look' for the X,Y of the circle to go high on touch to trigger a DOUT high.Maybe I'm just on the wrong track altogether.
cheers.
Posted: 05:35pm 10 Feb 2016
Hi-de-hi.
Yes, that makes a difference. I thought you meant MM+. I think you can just define an area on the screen where your circles are, and if you touch that area(which will also have the circle on it), then that will trigger the touch interrupt.
I will see if I can hook up a screen to a MM2 later on and have a play - I have only really tinkered with the MM+ touch side of things thus far.
Others will no doubt chime in with ideas, code snippets and examples I am sure.
Posted: 10:33pm 10 Feb 2016
Grogs,
Can you not 'frame' radio buttons in MMBasic?
If so, then have four 'frames' and each radio button will work independently of all the others!
Just an idea . . .
WW
Posted: 03:31am 11 Feb 2016
Just an idea, and a very good one!
Yes, I expect that should work.
However, that is MM+ GUI - I don't think radio-buttons and boxes are supported in the 28-pinner are they?
disco4now
Posted: 11:56am 11 Feb 2016
Geoff's ParkingAssist program shows some good methods of doing buttons/input etc on the 28 pin LCD backpack. Just comment out the lines for the hardware and you can get a good idea how it runs. There are some nice little routines that would be a good starting point for anything you want to do.
Thread where Geoff upload it
Gerry
F4 H7FotSF4xGT
Posted: 01:16pm 11 Feb 2016
Simple demo:
' OPTION LCDPANEL controller, orientation, D/C pin, reset pin [,CS pin]
' OPTION LCDPANEL ILI9341, RL, 4,5,6
' OPTION TOUCH T_CS pin, T_IRQ pin
' OPTION TOUCH 7,2
' GUI CALIBRATE
OPTION EXPLICIT
OPTION CLOCKTRIM -4
cls
SETPIN 26,DOUT ' display brightness
PIN(26)=1
COLOUR RGB(GREEN), RGB(BLACK)
FONT 1, 3
circle 50,50,40 'button1
circle 50,150,40 'button2
circle 150,50,40 'button3
circle 150,150,40 'button4
main:
DO
IF TOUCH(X) <> -1 THEN tapped
LOOP
END
SUB tapped
LOCAL tx,ty
tx=TOUCH(X)
ty=TOUCH(Y)
if ty > 0 and tx > 0 then
if tx > 10 and tx < 90 and ty > 10 and ty < 90 then
print "Button1"
endif
if tx > 110 and tx < 190 and ty > 10 and ty < 90 then
print "Button2"
endif
if tx > 10 and tx < 90 and ty > 110 and ty < 190 then
print "Button3"
endif
if tx > 110 and tx < 190 and ty > 110 and ty < 190 then
print "Button4"
endif
endif
pause 200
END SUB
Not sure if the display brightness pin is correct for your hardware.
The conditional statements could easily be improved depending on your layout.
Benzol
Posted: 02:00pm 11 Feb 2016
Hi Jim. that's awesome, I never ceased to be amazed by the expertise on this site. I'm at work and can't try it until I get home. Will let you know.
Regards db
