Local Time 07:33 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DHT22 on 100 pin
palcal
Posted: 07:59pm 07 Feb 2016
I have a DHT22 connected to pin 48 on the 100 pin chip with V 4.07
I'm getting values of 1000 C and 1000% I have checked the connections and the 4.7K resistor and the voltage at the DHT22. The chip is also running a TFT, pressure sensor and RTC and all are running OK. Tried another DHT22 same result.
Is it OK to use pin 48, the manual says 'any pin'.
Paul.
EDIT. Now working OK SMD resistor bad solder joint.
Sorry, another dumb mistake.
PaulEdited by palcal 2016-02-09
