Local Time 07:34 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Interrupt Issue
jman
Posted: 08:04pm 05 Feb 2016
Hi
Please take a look at the code below the issue
is that when the SetTick command is run from an interrupt
it does not work. If I run the settick command directly or before
an interrupt it works as expected.
What am I missing or is there a bug in the firmware
This is with a 44Pin MX170 MM v5.1
SetPin 8, Din
SetPin 9, Din
Main:
If Pin(8) = 0 Then GoTo TickTest
If Pin(9) = 0 Then GoTo ITest
GoTo Main
ITest:
Temp=0:Print "Interupt Loop"
SetPin 36, IntL, TickTest
End
TickTest:
Temp=0:Print "Got Here"
SetPin 36, Off
SetTick 300, OutInt, 2 'This does NOT run from Interrupt
Do While Temp < 10
Print Temp
SetTick 0, 0, 2
End
OutInt:
If OutC = 1 Then
OutC=0 : IReturn
OutC=1 : Temp=Temp+1
IReturn
Many Thanks
Jman
PicFan
Posted: 12:08am 06 Feb 2016
I think that is a problem with the Interrupt priority, the SETTICK have the lowest priority ?
Also i think it is not good a "do while" loop in a Interruptroutine ?
Posted: 01:20am 06 Feb 2016
I hope that's deliberately contrived (and horrid) code.
You want to keep any interrupt short. Preferably no PRINTs, too.
If you turn it into a more sane sample - which may be longer - does it then work?
If not, post it.
Yo might like to avoid IReturn and use a SUB in every case. Right now you even have TickTest apparently for an interrupt but no IReturn. It's not going to end well!!
JohnEdited by JohnS 2016-02-07
Posted: 02:47am 06 Feb 2016
There is nothing in the SETTICK command that would stop it from running correctly from within an interrupt. It just sets up the relevant registers and exits.
I suspect that it is something within your code.
EDIT: I think that I can see the problem. You run SETTICK from within an interrupt and your code will only exit this interrupt when the SETTICK interrupt has been called 10 times. But MMBasic will not service the SETTICK interrupt because it is already within an interrupt - you will never receive an interrupt within an interrupt.
GeoffEdited by Geoffg 2016-02-07
jman
Posted: 10:46am 06 Feb 2016
Hi
Ok so JohnS did not like the test code yes it was just test code.
Please see below and hopefully this is a better explanation
It seems that the SetTick command does not start until after
the interrupt routine has exited.
The code below uses SetTick then a pause at the start to prove
SetTick works during a pause
With the Interrupt routine the SetTick only starts after the pause
(ie the IReturn)
Hopefully this explains it a bit better
Jman
SetTick 500, OutInt, 2
Pause 5000
Print "Pause end"
SetTick 0, 0, 2
SetPin 8, Din
SetPin 36, INTL, ITest
Main:
If Pin(8) = 0 Then GoSub TickTest
GoTo Main
TickTest:
Print "Got Here from Button 1"
Pause 5000
Return
ITest:
Print "Got Here from Interrupt"
SetPin 36, Off
Pause 5000
IReturn
Sub OutInt
Print "Got here OutInt "
BobD
Posted: 11:44am 06 Feb 2016
jman
If I recall correctly, somewhere in the older manuals and maybe in the more recent ones, there used to be a listing of interrupt priorities. Also noted was that lower priority interrupts were masked off while a higher (or any?) interrupt was in progress. Also mentioned was that interrupts are not hardware but software and are processed at the end of the current instruction unless masked.
If I'm correct, would that make sense of your problem? It's too early in the morning for me to try analysis on it and we won at cricket and we didn't even have to bowl underarm.
Bob
jman
Posted: 12:08pm 06 Feb 2016
  BobD said   jman
Bob
So right you are from the manual page 40
"During the processing of an interrupt all other interrupts are disabled until the interrupt subroutine returns."
Great so now I know
Thanks for the help
Jman
