Forum Index : Microcontroller and PC projects : Since I have a composite ...
| hitsware Guru Joined: 23/11/2012 Location: United StatesPosts: 535 |
monitor : ..... ? http://www.vensmile.net/pro_detail.asp?id=278 |
Plonk one of these converter boxes on the end of the HDMI output, and ram that into your composite monitor. ...if that is what you were wanting to do... Smoke makes things work. When the smoke gets out, it stops! |
