Local Time 13:04 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : HMC5883L magnetometer
     Page 1 of 3
palcal
Posted: 11:50am 22 Jan 2016
Hi All,
I have ordered one of these modules, has any one done any work with this chip. I'm looking at making a compass.
Not sure if I will be able to get the calibration values from the chip, might need help with some code.
Paul.
Posted: 02:00pm 22 Jan 2016
It looks relatively easy to use. (Famous last words)
I just ordered a couple so give me a few weeks for them to arrive....
and hopefully by then, someone would have done the work.
greybeard
Posted: 02:14pm 22 Jan 2016
Attached rough code for simple testing. It just extracts the basic data, converts it into something readable. I used it to try and get a feel for how the output data changed as you rotated the module in the different axis.
2016-01-23_001224_hmc5883l.zip
cheers
Rod
Edited by greybeard 2016-01-24
palcal
Posted: 05:00pm 27 Feb 2016
Loaded the code that GREYBEARD supplied but there were some obvious errors with the
I2C OPEN, READ and WRITE commands that I have corrected but the line
"I2C READ HMC5883L_i2c, 0, 6, buf(0), 1, &h03" is the wrong syntax and I don't know what it should be.
Can anyone help
@TassyJim:- Did you receive your modules yet.
Paul.
Edit... Also a problem with the line "LOOP while a = a" Edited by palcal 2016-02-29
Posted: 05:06pm 27 Feb 2016
  palcal said
Can anyone help
Paul.
Yes I do.
I received it the day that my computers went up in smoke.
I have been putting it off in the hope that the insurance company will give me a shiny new computer to play with but I think it is time to learn to do more on this little netbook.
I find it hard reading PDF manuals on the small screen.
Posted: 07:55pm 27 Feb 2016
Here you go Paul
' test code for HMC5883L 3 axis digital compass
HMC5883L_i2c = &h1e
DIM buf(6)
PRINT "HMC5883L test"
I2C OPEN 100,100
' init hmc5883
I2C WRITE HMC5883L_i2c, 0, 2, &h00, &h70 '8-average, 15 Hz default, normal measurement
I2C WRITE HMC5883L_i2c, 0, 2, &h01, &hA0 'Gain=5, or any other desired gain
I2C WRITE HMC5883L_i2c, 0, 2, &h02, &h01 'Single-measurement mode
PAUSE 100
PRINT "init complete"
PRINT "x y z heading"
DO
PAUSE 6
I2C READ HMC5883L_i2c, 0, 6, buf(0) 'Read all 6 bytes
x = buf(0) * 256 + buf(1)
IF x >= &h8000 THEN x = x - 65536 ' Convert three 16-bit 2’s compliment
z = buf(2) * 256 + buf(3) ' hex values to decimal values and
IF z >= &h8000 THEN z = z - 65536 ' assign to X, Z, Y, respectively
y = buf(4) * 256 + buf(5)
IF y >= &h8000 THEN y = y - 65536
heading = DEG(Atn2(y,x))
PRINT x," ",y," ",z," ",heading
PAUSE 1000
LOOP WHILE a = a
END
FUNCTION atn2(y,x)
IF x > 0 THEN
atn2 = ATN(y/x)
ELSEIF y >= 0 AND x < 0 THEN
atn2 = PI + ATN(y/x)
ELSEIF y < 0 AND x < 0 THEN
atn2 = ATN(y/x) - PI
ELSEIF y > 0 AND x = 0 THEN
atn2 = PI / 2
ELSEIF y < 0 AND x = 0 THEN
atn2 = PI / -2
ENDIF
IF atn2 < 0 THEN
atn2 = atn2 + 2 * PI
ENDIF
END FUNCTION
I changed the I2C code to the current syntax.
I changed the reading mode to single shot rather than continuous.
The original code had the readings as x,y,z
The actual order should be x,z,y
Why, I don't know but that's the way it is.
I will worry about the self-test stuff later.
palcal
Posted: 09:55pm 27 Feb 2016
Thanks for that Jim it works OK but there is quite a variation in the heading without moving the module, I don't know what would cause that.
Here is a sample;
  Quote  HMC5883L test
init complete
x y z Heading
95 30 135 17.5256
104 27 137 14.5536
93 33 133 19.5367
106 28 136 14.7968
99 30 135 16.8584
98 31 134 17.5535
107 26 137 13.6576
94 32 133 18.7999
102 29 135 15.8712
103 28 136 15.208
94 33 133 19.3443
107 27 137 14.1622
99 30 135 16.8584
98 31 134 17.5535
107 26 137 13.6576
95 31 134 18.0723
100 30 134 16.6992
105 26 136 13.9078
93 33 133
Paul
Edit...It also shows East as 0 Degrees.Edited by palcal 2016-02-29
Posted: 11:20pm 27 Feb 2016
This is my output with no movement:
x y z heading
-64 -71 183 227.968
-65 -71 182 227.526
-65 -71 183 227.526
-64 -71 183 227.968
-64 -70 183 227.564
-64 -71 182 227.968
-64 -71 182 227.968
-65 -70 183 227.121
-64 -70 183 227.564
-64 -71 182 227.968
-65 -71 182 227.526
-65 -71 182 227.526
-64 -71 182 227.968
-65 -71 183 227.526
-64 -71 182 227.968
-65 -71 182 227.526
-64 -70 182 227.564
-64 -71 182 227.968
-65 -71 183 227.526
-64 -70 182 227.564
Which way is zero degrees is something that depends on the orientation of the chip on the board.
On mine, what I thought would be zero is at 45 degrees. (North East)
That can easily be adjusted in the maths.
Posted: 11:29pm 27 Feb 2016
Is the (large) variation in heading with Paul's setup likely to be caused by the HMC's external circuit?
6deg of variation is not as expected. Jim's is well within the 1-2deg tolerance.
Paul, what external circuit are you using?
I am needing a compass in a future project so keen to understand what is happening . . .
palcal
Posted: 10:11am 28 Feb 2016
I have the module connected to a 170, but it is in my metal workshop with a lot of wiring and equipment close by. When I get a TFT connected I will take it outside and see if that makes a difference.
Paul.
palcal
Posted: 02:23pm 28 Feb 2016
OK it is much more stable when I take it away from my workshop bench.
Since z is not used in the calculation I take it I have to adjust for Declination, also why the line, LOOP until a = a , why not just LOOP.
Paul.
Posted: 06:48pm 28 Feb 2016
Paul,
LOOP WHILE a = a was one way of running the loop 'forever'. I guess that it was needed in earlier versions of MMBasic or left over from other programming styles.
I have changed to LOOP in this version.
I have added a selftest SUB. It should let you know that your device is working correctly and I would be interested in comparing results.
AS far as Mag Declination goes, yes this device give you magnetic north and you need to adjust for 'true' north.
A good site to get your mag dec from is http://www.magnetic-declination.com/
I have converted the raw data into microTesla and allowed for setting different gain.
DIM buf(6)
DIM HMC5883L_i2c = &h1e
DIM HMC5883_MAGGAIN_1_3 = &h20' +/- 1.3
DIM HMC5883_MAGGAIN_1_9 = &h40' +/- 1.9
DIM HMC5883_MAGGAIN_2_5 = &h60' +/- 2.5
DIM HMC5883_MAGGAIN_4_0 = &h80' +/- 4.0
DIM HMC5883_MAGGAIN_4_7 = &hA0' +/- 4.7
DIM HMC5883_MAGGAIN_5_6 = &hC0' +/- 5.6
DIM HMC5883_MAGGAIN_8_1 = &hE0' +/- 8.1
DIM hmc5883_Gauss_LSB_XY
DIM hmc5883_Gauss_LSB_Z
DIM GAUSS_TO_MICROTESLA = 100
DIM magGain = HMC5883_MAGGAIN_4_7
SELECT CASE magGain
CASE HMC5883_MAGGAIN_1_3
hmc5883_Gauss_LSB_XY = 1100
hmc5883_Gauss_LSB_Z = 980
CASE HMC5883_MAGGAIN_1_9
hmc5883_Gauss_LSB_XY = 855
hmc5883_Gauss_LSB_Z = 760
CASE HMC5883_MAGGAIN_2_5
hmc5883_Gauss_LSB_XY = 670
hmc5883_Gauss_LSB_Z = 600
CASE HMC5883_MAGGAIN_4_0
hmc5883_Gauss_LSB_XY = 450
hmc5883_Gauss_LSB_Z = 400
CASE HMC5883_MAGGAIN_4_7
hmc5883_Gauss_LSB_XY = 400
hmc5883_Gauss_LSB_Z = 255
CASE HMC5883_MAGGAIN_5_6
hmc5883_Gauss_LSB_XY = 330
hmc5883_Gauss_LSB_Z = 295
CASE HMC5883_MAGGAIN_8_1
hmc5883_Gauss_LSB_XY = 230
hmc5883_Gauss_LSB_Z = 205
CASE ELSE
END SELECT
I2C OPEN 100,100
selftest ' not usually needed
' init hmc5883
I2C WRITE HMC5883L_i2c, 0, 2, &h01, magGain 'Gain=5, or any other desired gain
PAUSE 100
PRINT " x y z heading"
DO
PAUSE 6
xt = x /hmc5883_Gauss_LSB_XY * GAUSS_TO_MICROTESLA
yt = y / hmc5883_Gauss_LSB_XY * GAUSS_TO_MICROTESLA
zt = z / hmc5883_Gauss_LSB_Z * GAUSS_TO_MICROTESLA
PRINT STR$(xt,3,2),"uT ",STR$(yt,3,2),"uT ",STR$(zt,3,2),"uT ",STR$(heading,3,1)
PAUSE 2000
LOOP
END
SUB selftest
PRINT "Positive self test"
PRINT "values should be 243 to 575 for Gain=5"
I2C WRITE HMC5883L_i2c, 0, 2, &h00, &h71 '8-average, 15 Hz default, pos self test
I2C WRITE HMC5883L_i2c, 0, 2, &h02, &h00 'Single-measurement mode
PAUSE 6
FOR n = 1 TO 10
I2C WRITE HMC5883L_i2c, 0, 1, &h03 ' reset pointer to start of data
PAUSE 100
PRINT x," ",y," ",z
NEXT n
PAUSE 100
PRINT ""
PRINT "Negative self test"
PRINT "values should be -243 to -575 for Gain=5"
I2C WRITE HMC5883L_i2c, 0, 2, &h00, &h72 '8-average, 15 Hz default, neg self test
PAUSE 6
FOR n = 1 TO 10
PAUSE 100
PRINT x," ",y," ",z
NEXT n
PRINT ""
PRINT "Self test completed"
END SUB
FUNCTION atn2(y,x)
IF x > 0 THEN
atn2 = ATN(y/x)
atn2 = PI / 2
atn2 = PI / -2
ENDIF
IF atn2 < 0 THEN
ENDIF
END FUNCTION
palcal
Posted: 09:07pm 28 Feb 2016
@ TassyJim
I ran the test, but have absolutely no idea what it does.
These are my results.
HMC5883L test
Positive self test
419 417 394
419 417 394
419 417 394
419 417 394
419 417 394
419 417 394
419 417 394
419 417 394
419 417 394
419 417 394
Negative self test
121 -63 148
-410 -422 -384
-410 -424 -382
-411 -423 -383
-410 -422 -384
-411 -422 -383
-412 -422 -383
-411 -423 -384
-411 -423 -384
-411 -423 -382
Paul.
Posted: 09:38pm 28 Feb 2016
My readings were similar:
Positive self test
481 452 443
481 452 443
481 452 443
481 452 443
481 452 443
481 452 443
481 452 443
481 452 443
481 452 443
480 456 443
Negative self test
66 -455 181
-475 -457 -435
-473 -455 -435
-473 -455 -434
-471 -458 -435
-471 -455 -435
-472 -455 -434
-473 -456 -435
-471 -456 -435
4112 4112 4112
Self test completed
init complete
x y z heading
16.50 uT -1.00 uT 70.98 uT 356.5
16.50 uT -1.00 uT 70.59 uT 356.5
16.50 uT -1.25 uT 70.98 uT
According to the datasheet, this means that the chip is working correctly and the gain setting chosen is correct.
You can now rem out the call to selftest and forget that you ever saw those figures.
palcal
Posted: 09:53pm 28 Feb 2016
Thanks for all the help Jim.
Paul.
Posted: 09:55pm 28 Feb 2016
With a keen eye on this thread (and still awaiting my HMC5883's to arrive) I have to ask if this latest code is giving consistent headings; and using all data available to calculate a meaningful 'direction'
Also, does this latest code work any better for you (PalCal) in your workshop? The HMC is meant to be good to use in 'noise' environments. I intend to be using this chip on a robot buggy i.e. near 'noisy' motors so am keen to play with this asap.
@matherp EDIT: SORRY - I mean TassyJim - is your code 'heading' ( ) towards another version, or are all the calculations looking good from the responses here?
WW Edited by WhiteWizzard 2016-03-01
palcal
Posted: 11:13pm 28 Feb 2016
@WW
My module now displays steady readings on the bench in my workshop. I don't know what the cause of the fluctuations was but it is OK now.
Paul.
Posted: 11:22pm 28 Feb 2016
  palcal said   @WW
Paul.
Thats great to hear! Hoping now that the postman brings my chips this morning!!
Posted: 11:33pm 28 Feb 2016
@WW
There haven't been any real changes to my code.
All I did was convert the raw data to microTesla (data from the datasheets and an Arduino program)
My skills with 3D aren't good enough to play with the 3 axis any more than whats there so far.
My chip output agrees with a standard compass. It is off a lot on the bench and is probably within the quote 1-2 degrees when out in the clear.
Posted: 11:39pm 28 Feb 2016
Thanks Jim.
If you were to stand with your module held like a 'manual' compass (pointing out in front of you) and get a reading; does that reading remain consistent even if you turn the module upside down but still pointing in the same direction?
Make sense? I am basically wondering if 'spin' affects the reading while the unit points in a consistent direction (don't want to say 'spin about the axis' as this may be mis-interprretted!!)
WW
     Page 1 of 3
