Local Time 04:37 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to Send Hex String to (XBEE)
2001cpx
Posted: 08:45am 13 Jan 2016
Hi!
i`ve tried to find answer by Searching all the forum whitout succes.
My Problem,same as 3 years ago,is i want to send (i Use MAXIMITE) Hex string to
xbee (Api Mode)but if i wrote a line with chr$(&h7e) etc
i have an error,like line too long.
i want to send this via serial to xbee
7E 00 10 17 01 00 00 00 00 00 00 FF FF FF FE 02 44 30 05 71
Does anyone have some tips about this?
i need to use API mode,i can`t use Ascii
Thanks in Advance!!
"Color Maximite,(Duinomite-Mega,Mini),CGmmStick,GCmicroboard2b,Micromite + explore 64,100,LCD backpack,Lcd Backpack V2,TFT Backpack,Micromite Extreme,Armmite L,F,H,CMM2"
Posted: 08:59am 13 Jan 2016
chr$(&h7e) will work fine.
If using PRINT or the like you need either chr$(...)+chr$(...)+...
or use ; instead of each +
If you got line too long it had an error - post the line so we can figure out what.
JohnEdited by JohnS 2016-01-14
ajkw
Posted: 03:35pm 13 Jan 2016
Perhaps something like this
Dim out$(20) = "7E","00","10","17","01","00","00","00",....
Outpos = 0
Print #1,val(out$(outpos)) ' send to the serial port 1 the value of the array element
Outpos = outpos + 1
Loop until outpos = 20
Sample code not checked or verified working. I am away from my mite to check the Print output structure is correct.
Edit perhaps it should be
Print#1,chr$(val("&H"+out$(outpos)))
There will be a better way but hopefully this helps.Edited by ajkw 2016-01-15
Posted: 05:28pm 13 Jan 2016
using
PRINT #1, chr$(&h7e)+chr$(&h7e)+chr$(&h7e)+chr$(&h7e)+chr$(&h7e) ...
will make the line too long for MMBasic
You can print the line in two or more stages provided you end the line with ; to suppress the CR
PRINT #1, chr$(&h7e)+chr$(&h7e)+chr$(&h7e);
You might be able to divide the string up into meaningful sub-strings.
Strings can contain chr(0) so it is OK to do this:
header$=chr$(&h7e)+chr$(&h7e)+chr$(&h7e)
body$ = chr$(&h7e)+chr$(&h7e)+chr$(&h7e)
end$ = chr$(&h7e)+chr$(&h7e)+chr$(&h7e)
PRINT #, header$+body$+end$;
If you need the CR at the end, leave the ; off.
2001cpx
Posted: 05:41am 14 Jan 2016
Thanks!,
i will try it
