Local Time 18:46 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : "not enough memory"
expo
Posted: 10:57pm 09 Jan 2016
Hello from my first post.
I have MMII(170) and a programme about 1760 bytes. When I add to the programme a little bit and upload using MMEdit and run I get a "not enough memory" error. From Geoff C's website it appears that the 170 should be able to handle ~80K of programme and up to 2,500 lines of code (mine is 76).
I am not using any arrays, have about nine variables only.
I have used Tera Term to List and see the last few lines missing.
Is this likely to be correct, or am I getting something wrong.
Thanks,
greg
Posted: 11:05pm 09 Jan 2016
Hello and welcome to the forums.
This is a bit odd. I assume you are using a recent version of MMEDIT, and that you have Micromite Syntax selected?
Try this:
1) Save a current version of your code in MMEDIT
2) Open Tera Term, and type XMODEM R at the command prompt and then ENTER.
3) In Tera Term, goto FILE/TRANSFER>/XMODEM>/Send...
4) Select the file you saved in MMEDIT, and click OK.
The file should nip across to the MM, and you should see a progress window.
Does the file transfer over OK that way?
Does it run?
expo
Posted: 11:21pm 09 Jan 2016
Hello Grogster,
Thanks for the suggestion but xmodem gave the same error report "Error: Not enough memory". BTW I have tried a brand new MMII pre-loaded from SC as well - same result.
panky
Posted: 11:32pm 09 Jan 2016
Greg,
What does the command "memory" return?
Also, what version of MMBasic?
Doug.
Edit: By that I mean, at the command prompt on the MM2, enter memory and please post the result.Edited by panky 2016-01-11
expo
Posted: 11:37pm 09 Jan 2016
Hello Doug,
> xmodem r
> memory
Flash:
1K ( 1%) Program (52 lines)
59K (99%) Free
RAM:
0K ( 0%) 0 Variables
0K ( 0%) General
53K (100%) Free
MM.VER returns 4.06
greg
Posted: 11:41pm 09 Jan 2016
Greg
If there isn't anything confidential can you post your program and we can see what is happening.
Peter
expo
Posted: 11:42pm 09 Jan 2016
Hello Doug,
....that was for the shorter version that uploads and runs OK. Let me try the one that doesn't and I'll get back to you. (the longer version is only a few lines longer...)
greg
Posted: 11:50pm 09 Jan 2016
Yes, please post code if it is not confidential as matherp says.
I have a feeling you have DIM'ed something in the array or string area of things, which is gobbling up all the available RAM. The code will tell us, if you are willing to post it.
expo
Hello Doug,
Here is the code (for SIMCOM 5320 3g modem - fwiw)
OPTION AUTORUN ON
watchdog 5*60*1000 'this 5 mins is for testing only. Use 24hrs for permanent.
const dev_id%=29001
DIM amb_temp!=15.5,vbatt1!=14.8,amb_light%=225,vbatt2!=12.8,b6!=13.9,D$ length 64="1",DD$ length 3="111",DDD%=111,count%=1
server$="aaa.bbb.ccc.ddd"
portREM$="wxyz"
portLOC$="pqrs"
setpin 14, dout
pause 20000
settick 60000,TRANS,1
open "Com1:115200" AS #1
pause 2000
DO
LOOP
SUB TRANS
watchdog 180*1000
print #1, "AT+CIPCLOSE=1"
print "AT+CIPCLOSE=1"
pause 1500 : flushbuf
print #1, "AT+NETCLOSE"
print "AT+NETCLOSE"
Print #1, "AT+NETOPEN"
print "AT+NETOPEN"
print #1, "AT+CIPMODE=0"
print "AT+CIPMODE=0"
print #1, "AT+CIPSENDMODE=0"
print "AT+CIPSENDMODE=0"
print #1, "AT+CIPOPEN=1," + CHR$(34) + "TCP" + CHR$(34) + "," + CHR$(34) + server$ + CHR$(34) + "," + portREM$ + "," + portLOC$
pause 1000
print "AT+CIPOPEN=1," + CHR$(34) + "TCP" + CHR$(34) + "," + CHR$(34) + server$ + CHR$(34) + "," + portREM$ + "," + portLOC$
pause 1000
If LOC(#1)<>0 then
D$=INPUT$(LOC(#1),#1)
Endif
DD$=RIGHT$(D$,3)
DDD%=VAL(DD$)
print #1, "AT+CIPSEND=1,"
print #1, chr$(13)
pause 200
print #1, STR$(dev_id%,5)","STR$(amb_temp!,2,1)","STR$(vbatt1!,2,1)","STR$(amb_light%,3)","STR$(vbatt2!,2,1)","DD$","STR$(DDD%,3)" ,"STR$(dev_id%,5)","STR$(amb_temp!,2,1)","STR$(vbatt1!,2,1)","STR$(amb_temp%,3)","STR$(vbatt2!,2,1)","DD$","STR$(DDD%,3) ","STR$(dev_id%,5)","STR$(amb_temp!,2,1)","STR$(vbatt1!,2,1)","STR$(amb_temp%,3)","STR$(vbatt2!,2,1)","DD$","STR$(DDD%,3 )","STR$(count%,4) + CHR$(10) + CHR$(26)
print STR$(dev_id%,5)","STR$(amb_temp!,2,1)","STR$(vbatt1!,2,1)","STR$(amb_light%,3)","STR$(vbatt2!,2,1)","DD$","STR$(DDD%,3)" ,"STR$(count%,4)
if DDD%=256 then pin(14)=1
pause 2500
pin(14)=0
IF count%=1440 then count%=1
count%=count%+1
amb_temp!=amb_temp!+0.1
print "AT+NETCLOSE"
pause 1500
END SUB
sub flushbuf
watchdog 50000
do : loop until INPUT$(255, #1) = ""
end sub
Thanks for the help.
greg
expo
Posted: 11:52pm 09 Jan 2016
sorry Peter, didn't notice the change of poster!
g
panky
Posted: 11:53pm 09 Jan 2016
Greg,
Looks like you are running 4.7beta36 - if you have a Pickit 3, it might be an idea to come up to the stable 4.7beta37 or even Geoff's new 5.0.
Also, Peter's request for the program may help us assist you if it is not confidential
Doug.
Posted: 11:57pm 09 Jan 2016
The problem is lines 53 and 54 which are longer than 255 characters
split them as below:
print #1, STR$(dev_id%,5)","STR$(amb_temp!,2,1)","STR$(vbatt1!,2,1)","STR$(amb_light%,3)","STR$(vbatt2!,2,1)","DD$","STR$(DDD%,3)" ,"STR$(dev_id%,5)";
PRINT #1,"STR$(amb_temp!,2,1)","STR$(vbatt1!,2,1)","STR$(amb_temp%,3)","STR$(vbatt2!,2,1)","DD$","STR$(DDD%,3) ","STR$(dev_id%,5)","STR$(amb_temp!,2,1);
print ","STR$(vbatt1!,2,1)","STR$(amb_temp%,3)","STR$(vbatt2!,2,1)","DD$","STR$(DDD%,3 )","STR$(count%,4) + CHR$(10) + CHR$(26)
Edited by matherp 2016-01-11
expo
Posted: 12:01am 10 Jan 2016
Hello Glen?, Doug & Panky,(... it appears I'm more interested in my problem than who is posting help!)
I don't have a means of upgrading the firmware ..yet (slow boat from...).
I would be surprised if a firmware revision would affect the memory useage in that way, but then again I am a newbie!
g
[Quote=matherp]The problem is lines 53 and 54 which are longer than 255 characters [/Quote]
Agreed.
Subtle error though, as I note that the console says there is PLENTY of memory available, so this was a bit of a curly one!
expo
Posted: 12:28am 10 Jan 2016
Thanks Peter and Glen and Panky,
...a simple, elegant solution...but only if you have the knowledge!
berst wishes,
greg
lew247
Posted: 02:40pm 24 Nov 2017
I've just had this problem
I'm using an E100 board to run my weather display program
[quote][758] Local integer x0a,y0a,x1a,y1a,x2a,y2a
> memory
Flash:
57K (57%) Program (1234 lines)
11K (10%) 5 Embedded C Routines
4K ( 4%) Library
28K (29%) Free
RAM:
73K (71%) 120 Variables
25K (23%) General
5K ( 6%) Free
[/quote]
The only thing I did differently was increase the size of the pointer from
dim integer ptr(5)=(-7,0, 7,0, 0,-85) ' define size of the pointers
to
dim integer ptr(5)=(-7,0, 7,0, 0,-95) ' define size of the pointers
relating to
This SUB
[code]sub rotatetriangle(n as integer, col as integer, angle as float, x as integer, y as integer, x0 as integer, y0 as integer, x1 as integer, y1 as integer, x2 as integer, y2 as integer)
local float sine=sin(rad(angle)),cosine=cos(rad(angle))
local integer x0a,y0a,x1a,y1a,x2a,y2a
x0a= x0*cosine - y0 * sine + x
y0a= y0*cosine + x0 * sine + y
x1a= x1*cosine - y1 * sine + x
y1a= y1*cosine + x1 * sine + y
x2a= x2*cosine - y2 * sine + x
y2a= y2*cosine + x2 * sine + y
xx0(n)=x0a
yy0(n)=y0a
xx1(n)=x1a
yy1(n)=y1a
xx2(n)=x2a
yy2(n)=y2a
tcol(n)=col
end sub[/code]
EDIT: I fixed the problem by changing the pointer size
I'm just curious why it happened when it seems I had lots of memory still availableEdited by lew247 2017-11-26
