Local Time 04:37 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Auto Updating firmware in MM+
atmega8
Posted: 07:03am 08 Jan 2016
Hello,
(how) is it possible to auto-update the program in an MM+ via SD-CARD on site?
It should be possible to detect a program Update on a MM+ via SD-Card.
Idea:
Copy the new program on a sd-card, send it to the site, pluig in the SD-Card, reboot,
the MM+ detects a new version, copy's it automaticaly to program memory (flash) and restarts with tne new program?
Would this be a working solution?
Has anyone another idea?
Proof of concept?
THX
Atmega8
boss
Posted: 08:15am 08 Jan 2016
@atmega
If you want to update MM FW you have to erase the PIC chip. So the answer is no
it is impossible to update the FW from SD card yet.
Bo
Posted: 08:33am 08 Jan 2016
It is possible.
You would first need to load a program in RAM that will read the flash and write those values in flash. Or you reserve a part of the flash for a bootloader.:)
Which is already done many times. Most of them use the USB as a means to get the data to be programmed into flash. The data could just as well come from an sd card.
atmega8
Posted: 10:59am 08 Jan 2016
@ Boss
I Never talked about a Firmware (Mmbasic) Update,
The Question is about updating the programm running in the Mite, from sdcard.
Has anyone a detailed description for a working procedure?
THX
Posted: 11:41am 08 Jan 2016
That is easy, just use:
LOAD file, R
The ,R suffix causes the program to be run immediately after it has been loaded.
atmega8
Posted: 08:30pm 08 Jan 2016
And before i will Check If the content of The sd Card IS differen, newer or whatever than The Programm in The
Then load it with load.
Done.
Thank you all.Edited by atmega8 2016-01-10
Posted: 11:55pm 09 Jan 2016
  atmega8 said   @ Boss
I think Boss was reading the Title of your thread which clearly mentions Firmware!
atmega8
Posted: 10:11am 10 Jan 2016
Uahh,
mea culpa, sorry
