Local Time 04:02 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RGB(..) does not return correct value
Bizzie
Posted: 03:30pm 07 Jan 2016
Hi all,
Has anyone come across this before?
> Micromite Plus MMBasic Ver 4.7 Beta 36
Copyright 2011-2015 Geof>
> option list
OPTION BAUDRATE 115200
OPTION LCDPANEL ILI9341, LANDSCAPE, 21, 22, 23
OPTION TOUCH 18, 14
OPTION SDCARD 49
> list
CLS
Cl = RGB(255,255,255)
Print Hex$(Cl),Hex$(RGB(255,255,255))
Line 25,25,100,100,1,RGB(255,255,255)
Line 50,25,100,100,1,Cl
> run
1000000 FFFFFF
[13] Line 50,25,100,100,1,Cl
Error: 16777216 is invalid (valid is 0 to 16777215)
Rob White
Posted: 03:40pm 07 Jan 2016
Cl has to be an integer to fit the resulting number into it.
variables default to floating point unless specified otherwise
CLS
dim Cl as integer
Bizzie
Posted: 03:49pm 07 Jan 2016
Thanks Jim,
Another case I knew the answer would be simple. I will have to get into the habit of declaring a variables type.
Rob White
