Local Time 06:24 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SD card access problem
Bizzie
Posted: 06:48pm 02 Jan 2016
Hi I have just taken delivery of two CGmicroboard2b's.
I can not get access to the micro SD cards.
I have typed (as per page 12 of MM+ manual):-
> Micromite Plus MMBasic Ver 4.7 Beta 36
Copyright 2011-2015 Geof
> option sdcard 49
Restart the Micromite+
> files
Error: Cannot access the SD card
> option list
OPTION SDCARD 49
I have tried three different SD cards (2,2 and 8 GB of differing brands) both have files written to the card by a CGColorMax2 board and they are recognized by Win10.
Pin 49 does indeed seem to be connected to pin 1 of the SD card.
What am I doing wrong?
Rob
Rob White
Posted: 07:07pm 02 Jan 2016
According to CG's website, pin 30 is used for card detect so the command should be
OPTION SDCARD 49, 30
I would the command you used to work but it is worth a try.
Bizzie
Posted: 07:51pm 02 Jan 2016
Thanks Jim for your reply.
I am afraid it did not help!
> option sdcard disable
> option sdcard 49, 30
> files
Rob
Rob White
CircuitGizmos
Posted: 06:52am 03 Jan 2016
I'm a bit out of touch right now as I have a dying family member and life chaos.
Rob, please visually inspect the microcontroller and SD card pins for bad connections.
CircuitGizmos
Posted: 05:59pm 04 Jan 2016
If there are bad connections, please let me know.
MikeO
Posted: 09:08pm 15 Jan 2016
@ Bixzzie
Did this get resolved ? I have been experiencing this same problem today. I did check all the connections and they seemed OK and it then worked however it then stopped again. I have tried 2 GC boards and both seem to exhibit the same problem. I have noticed that if I do files *.* without a SD card it reports cannot access the sd card , if I then try with a sd card in the slot it report 0 files, but there are files .
I will double check connections but seems unlikely on two boards, BTW one board has B36 the other B37 , same symptoms.
Mike
Codenquilts
Posted: 09:44pm 15 Jan 2016
@MikeO
I have seen this along the way while testing MM's. The only trouble is that I can't remember which version of MMBasic it was (sorry )
Can I ask out of interest what capacity SD card you are using?
If it is 2Gb (or less) can I suggest trying a higher capacity card as it has been identified some SD cards cause an issue.
Last year I spent a long time trying to resolve an issue with LOAD IMAGE, and with GUI TEST LCDPANEL (the circle drawing test); both commands then causing the '0 files' message.
Both these commands were resolved by changing the SD card.
WW
Edited by WhiteWizzard 2016-01-17
MikeO
Posted: 10:29pm 15 Jan 2016
OK, I was using an 8gb card, I will have to do more investigation because I definitely had this working ok and actually loaded and displayed an image file.
I have noted that
> files *.*
0 directories, 0 files Gives me this, obviously wrong
however files on it own without any filter gives me the following .
> files EDIT: I have just noted that the filespec is optional , but the wild cards should have worked ??
0 directories, 18 files
>Edited by MikeO 2016-01-17
Codenquilts
MikeO
Posted: 10:51pm 15 Jan 2016
OK, for my immediate use the problem is solved. It does in fact load and display the bitmap file but I was thrown by the fact that you cannot display the files when you include any form of filespec, "files" on its own is OK.
Mike
Codenquilts
Posted: 11:03pm 15 Jan 2016
@MikeO
The issue you report about FILES *.* was a bug and has indeed been fixed by Geoff in B38.
He hopes to be releasing another version of firmware soon; so for now please just use FILES (as you mention).
WW
MikeO
Posted: 11:20pm 15 Jan 2016
Oh Gosh , OK, is there a concise bug list anywhere that i could have consulted before rushing off on a tangent!! It hard to keep up reading all the posts.
Thanks again.
Codenquilts
Posted: 11:38pm 15 Jan 2016
@MikeO,
I know what you mean about keeping up-to-date with all the posts; however, please do remember that the MM+is still not 'officially' released on Geoff's website yet.
TBS members have the privilege of using his 'developments' first but remember it is still in Beta until he officially releases it. Therefore expect a few niggles (but only a few mind!). And the more people play with the MM+, the more chance of 99.99% everything working (there will always be something 'uncovered' when used in certain combinations).
There is an 'issue' list with each Beta software he releases but obviously this only lists the things known about at the time. I spend many man-hours stress testing MMBasic and uncover some real strange ones which never get documented as they are so extreme.
The thing to be re-assured with though is that Geoff fixes things almost as soon as he is informed about them - very impressive when you look at what he has created.
If you PM him I am sure he will be happy to send you his latest Beta which has almost everything fixed. He is wanting to release v5.0 as soon as he is happy with it; and no doubt he can give you his latest update regarding timescales.
In the meantime - please post any issues you find as it is good to know about them even if they have already been fixed . . .
WW
MikeO
Posted: 11:58pm 15 Jan 2016
Thanks , believe me I understand this is a beta, thanks for your time.
Codenquilts
