Local Time 04:03 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : data in library
drkl
Posted: 11:51pm 27 Dec 2015
Hello,
Here is the begining of a code: (MM V5.0)
'LB-LOGGER.BAS
'PROGRAMBA:
DIM MD(12),I
DATA 0, 31, 59, 90, 120, 151, 181, 212, 243, 273, 304, 334
FOR I = 1 TO 12: READ MD(I): NEXT I
when I put it into library, I have got:
>run
[LIBRARY] For I = 1 To 12: Read MD(I): Next I
Error: No DATA to read
Without using the library the code works well.
Where did I make a mistake?
drk
Posted: 12:36am 28 Dec 2015
From the user manual page 16:
  Quote  You can use READ commands in the library but they will default to reading DATA statements in the main program memory. If you want to read from DATA statements in the library you must use the RESTORE command before the first READ command. This will reset the pointer to the library space.
Don't worry that you did not see it. There is a lot in the manual to adsorb.
drkl
Posted: 12:58am 28 Dec 2015
Hi Geoff,
Many thanks, the bad thing is, that I trasanslated the manual to hungarian...
I forget it...Sorry
The hungarian translation (to practice he hungarian ):
• A könyvtárban használhatjuk a READ parancsot, de ez az alapértelmezés szerint a program memóriában elhelyezett DATA utasításban szereplő adatokat olvassa. Ha mégis a könyvtárban szereplő DATA adatait akarjuk kiolvasni, akkor az első READ parancs használata előtt a RESTORE parancsot kell kiadni. Ez a mutatót a könyvtár területre állítja.
Many thanks again
drk
drkl
Posted: 01:23am 28 Dec 2015
I have a newer problem:
The beginning of a program in the library:
restore
DIM MD(12),I
'++++++[ DATE,TIME <> 64B KONVERZIOK]++++++++++++++++++++++++++++++++++
SUB DTESZT
LOCAL K%
? DATE$: ? TIME$
PERCEK(K%): ? GETDATM$(K%): ? GETTIMM$(K%)
MPERCEK(K%): ? GETDATS$(K%): ? GETTIMS$(K%)
END SUB
'XXXXXX[ PERC ALAPU KONVERZIO ]XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
'******[ CALCULATE THE MINUTES SINCE MIDNIGHT 1ST JAN 2014 ]***********
FUNCTION GETMINS%(YR, MTH, DAY, HR, MIN)
GETMINS% = (YR - 14) * (365 * 24 * 60) + ((YR - 13) \ 4) * (24 * 60)
GETMINS% = GETMINS% + (MD(MTH) * (24 * 60))
I've got a error message:
[LIBRARY] GETMINS% = GETMINS% + (MD(MTH) * (24 * 60))
Error: Variable not declared
By my opinion the MD() is a global variable
Without transferring the program to the library it operates well.
Any help?
drk
drkl
Posted: 01:53am 28 Dec 2015
Hi.
I answer to myself, here is the solution
SUB MM.STARTUP
LB_INIT
END SUB
SUB LB_INIT
RESTORE
DIM MD(12)
END SUB
drk
