Local Time 04:38 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PIC Program MMbasic with no HW
atmega8
Posted: 01:16am 26 Dec 2015
wasn't there a method to program a PIC with MMbasic, without any additional Hardware?
If not, what is the minimal interface circuit for it?
Thanks for clearification an Merry X-MAS.
Atmega
Posted: 01:45am 26 Dec 2015
I seem to recall reading a thread about that some time ago, but I think although it was theoretically possible, it would take MMBASIC about 20 minutes to program one chip or something like that.
Posted: 03:09am 26 Dec 2015
G8JCF, JohnS, and myself all experimented with using a micromite as the programming hardware, but as Grogster recalls there were various issues around the programming time required. the best i ever achieved was something like 15 minutes, JohnS had a solution that used an FTDI bridge chip but took some number of hours, while G8JCF wrote a custom function that managed a couple of minutes or less.
when i moved from using JTAG to ICSP interface i changed over to using an arduino nano to address programming time as well as provide a solution that didn't require any 'bootstrapping' (the nano shipping with a bootloader already present, and costing only a few dollars).
rob :-)Edited by robert.rozee 2015-12-27
atmega8
Posted: 03:12am 26 Dec 2015
Time doesn't matter.
What was the best usefull Solution?
Link?
Posted: 04:40am 26 Dec 2015
imho, pic32prog along with an arduino nano. the nano is dirt cheap from ebay (less than us$2.50 delivered), and pic32prog is current software that is being maintained and updated by serge as new pic32 devices are released.
abridged construction details:
2015-12-26_143947_constructor_guide.pdf
btw, Grogster has produced a PCB for a far neater assembly.
Posted: 05:21am 26 Dec 2015
Depends a bit which PIC chip(s) as some need rather high voltage (Vpp). The nano etc don't have that at the moment I think.
I also did a few very fast versions:
1. using a Raspberry Pi (15 secs or so)
2. you buy 2 of the cheapest Arduino programmers there are (usbisp / usbasp) and it's something like 30 secs
The above 2 don't need any zener diodes etc (I don't own any). Very very simple.
The horribly slow way you use a USB serial port, plug it into your desktop/laptop and the programming software wiggles the lines (DTR/DSR/etc) which you connect to the ICSP pins. (It's GPIO via USB packet.)
I was only looking at PIC32 at the time, no high voltage Vpp stuff.
JohnEdited by JohnS 2015-12-27
