Local Time 04:03 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RTC GetTime/ RTC SetTime
jman
Posted: 03:45pm 25 Dec 2015
Hi All
So I noticed that when using I2C and you use the built in RTC commands
after the command ie RTC GetTime or RTC SetTime
the I2C is ALLWAYS closed and a new Open command is required.
So is this known / Bug or by design
I2C Open 100,100
RTC GetTime
I2C Write &H44, 0, 2, &H01 ,&H00
End
The code above Produces
[14] I2C Write &H44, 0, 2, &H01 ,&H00
Error: Not enabled
While the following works as expected
RTC GetTime
I2C Open 100,100
End
This is also applies to the RTC SetTime command
Jman
Posted: 04:03pm 25 Dec 2015
Interesting.
I get the same problem with your test code, so it might be an elusive bug perhaps?
Manual says(page 63):
  MMBASIC Manual said  If the I2C bus is already open the RTC command will use the current settings, otherwise it will temporarily open the connection with a speed of 100KHz.
This suggests that the command will use the current I2C settings, but it would indeed seem that the I2C port is being closed by the GetTime command - odd.
Watching this thread with interest....
Posted: 06:12pm 25 Dec 2015
It is a bug and now that it has been pointed it out I can see it in the source - as obvious as the nose on my face!
I will fix it in the next release. Thanks Jman and Grogs.
