Local Time 03:15 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to use OPTION LCDPANEL ?
kiiid
Posted: 11:57am 14 Dec 2015
> option lcdpanel SSD1963_7, Landscape, 28, 27
Error: Incorrect argument count
> option list
OPTION LCDPANEL SSD1963_7, ST7735
Apparently a bug there as ST7735 is not SSD1963.
Is this the correct format of the command according to page 41 in the Advanced Features PDF?
The D/C pin is 28, RESET is 27, and CS is permanently grounded in my board.
What is the correct format of this command?
Edited by kiiid 2015-12-15
http://rittle.org
Posted: 12:40pm 14 Dec 2015
  Quote  Beta 36
- To setup an SSD1963 panel the command now is:
OPTION LCDPANEL SSD1963_x, orientation [, backlight-pin]
ie, the default font option has been removed.
What chip and what version of MMBasic are you using?
Posted: 08:16pm 14 Dec 2015
I assume that you are using beta 37 on a 64-pin MX470 with a a SSD1863.
It sounds as if you are using some old documentation for the MM+. The correct command is:
OPTION LCDPANEL controller, orientation [,LCD-A pin]
'controller' can be either:
• SSD1963_4 For a 4.3 inch display
• SSD1963_5 For a 5 inch display
• SSD1963_5A For an alternative version of the 5 inch display if SSD1963_5 does not work
• SSD1963_7 For a 7 inch display
• SSD1963_7A For an alternative version of the 7 inch display if SSD1963_7 does not work.
'orientation' can be LANDSCAPE, PORTRAIT, RLANDSCAPE or RPORTRAIT (or L, P, RL or RP). 'LCD-A pin' can also be any I/O pin but is optional. This can be used to control the brightness of the backlight if the internal SSD1963 controller is not used.
The default font has been moved to the console configuration command:
OPTION LCDPANEL CONSOLE [font [, fc [, bc [, blight]]]
'font' is the default font, 'fc' is the default foreground colour, 'bc' is the default background colour and 'blight' is the default backlight brightness (2 to 100). These are all optional and default to font 2, white, black and 100%.
