Local Time 03:16 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : lcd panel exist?
drkl
Posted: 12:56pm 12 Dec 2015
Hello,
I would like the program to verify the existence of the LCD panel. There's some possibilities, such as a boolean?
Waiting for answer, thanks
drk
Posted: 04:10pm 12 Dec 2015
you mean the TFT colour LCD display, or the monochrome HD44780 display? i recall some mention in an earlier thread of a configured but missing TFT display causing an issue. the HD44780 display, by contrast, is used as a 'write only' device and it being missing can not be detected in code.
rob :-)
Posted: 05:54pm 12 Dec 2015
The ILI9341 based LCD panels are also "write only", ie, MMBasic does not try to read from them.
At this time I cannot think of a method of discovering if the display is actually connected.
drkl
Posted: 10:08pm 12 Dec 2015
The problem is that the LCD panel pin definitions like to use for other purposes when there is no LCD panel. It would be good if there is no LCD panel then the MM.MVRES, MM.HRES variables return a zero instead of an error message.
drk
Posted: 10:31pm 12 Dec 2015
Good point and easily done. I will put it into the next version.
