Local Time 02:25 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : BAD engineering....
Posted: 12:17am 25 Nov 2015
I must admit to being an EEVblog subscriber, and although Dave gets a little carried away with his criticisms on this video(rants a bit), he still makes good points - it's pretty bad!
World's Worst Tablet
All I can say is I am glad I don't build like this. Hell, I would not even build like that for my own use - you're asking for faults that you have to try to trace later.
CircuitGizmos
Posted: 06:17am 25 Nov 2015
I think that the power supply was soldered over a camp fire.
Posted: 02:37pm 25 Nov 2015
Yeah, I have to agree with Dave when he says just use an off-the-shelf power brick.
Those 12v to ATX adaptors are not that expensive.
I have a feeling I know what is going on here, and it is as simple as PROFIT.
In order to maximize profit, make the thing absolutely as cheap as possible - that includes hacking a PSU at home rather then buying a ready-made module(saves a few cents), soldered battery packs(another buck or saved over using holders), etc, etc etc....
The thing that blows my mind, is the USB connection for the touch - as Dave says - why not just use a ready made USB cable? Hacking the cable and soldering it on would surely take longer and cost more in the long run to do, then to just plug in a ready-made cable!
Amazing.....
Justplayin
Posted: 03:04pm 25 Nov 2015
I don't see what Dave is complaining about. Every project I ever put together uses those very same assembly techniques. It all fit inside the case AND powered on! What else could you possibly ask for.
--Curt
Posted: 03:36pm 25 Nov 2015
Chances are the contract went to the lowest bidder.
I tend to agree with Curt, if it worked, and was reliable, then is doesn't really matter how horrible it looks on the inside. When your competing for a contract, you need to keeps costs down, and internal cosmetic appearance is not important.
Posted: 03:50pm 25 Nov 2015
Dave does not like rough assembly though, does he?(rhetorical)
Justplayin
Posted: 03:52pm 25 Nov 2015
Joking aside... I've assembled custom designed show control systems for Disney, Sea World and other entertainment companies and one thing I was proud of was how neat and organized they were inside. I spent a lot of time figuring out the best ways to run the wires or hide them.
The inside of that tablet made me cringe.
--Curtis Edited by Justplayin 2015-11-27
Posted: 08:58pm 25 Nov 2015
Thanks for posting that one Grogs,
I don't feel so bad now about some of my prototypes...
I often don't agree with Dave and feel he is too critical but I think in this case I would agree that is DODGY.
Honestly a cheap PSU board and lithium battery pack would have been readily available for no more than they probably paid for the ones in that unit..
I could, almost, forgive the `hot snot' VReg on the cover but I think a screw mounting with a nice smooth round head would have been easy and more professional.
I do really like the CPU board though, I wish I found some in a `dumpster dive'
