Forum Index : Microcontroller and PC projects : The Esc button...
| kiiid Guru Joined: 11/05/2013 Location: United KingdomPosts: 671 |
Geoff, I am returning back to my earlier request as I really need this. Would it be possible if the virtual keyboard for entering values have an "Esc" button in the Alt page? I see the top right one next to "CE" is blank, so it will be the ideal place for it. Or maybe swap "Esc" and "<<<" places for compatibility with everything else in the world? The "<<<" button also would be better if called "Del", I think, because right now people get confused that it is for returning to the previous page. Thanks! http://rittle.org -------------- |
If it means anything, I thought that "<<<" meant previous page.... Smoke makes things work. When the smoke gets out, it stops! |
Yes, sorry about that... it was something that I meant to address. My MX470 test setup had a major meltdown. It was a jumble of breadboards and jumpers and very unreliable. I have just finished building PeterM's board as a more reliable replacement so I will be able to get back to developing the Micromite+ version. I should have a new beta out in a couple of weeks and I will endeavour to put this in. Geoff Geoff Graham - http://geoffg.net |
That's great. Thank you very much! http://rittle.org -------------- |
