Forum Index : Microcontroller and PC projects : VAR save and restore(mainly save)...
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10028 |
Hi folks.
The VAR SAVE command is very handy, but I have found that there is a situation where you have lots of variables you want to save, and they cannot be fitted on the one command line. Has any thought been given to allowing more then one VAR SAVE line? VAR SAVE 1, VAR SAVE 2 kind of thing. VAR RESTORE could work the same way: VAR RESTORE 1, VAR RESTORE 2 etc. With the stereo project that jman and I are alpha testing, I am wanting to save all the current settings of the preamp using the likes of VAR SAVE, but there are too many variables to list on the one VAR SAVE command. Any thoughts? Perhaps a Cfunction could be written to get around this? Not sure if Cfunctions can play with the flash memory - they might only be for number-crunching and speed for graphics drivers etc, which probably don't play about with the flash, only the RAM. I would use an I2C EEPROM, but I forgot to add one, so VAR SAVE is really my only realistic alternative. I had a light-bulb moment, and thought of copying all the variables into an array, but VAR SAVE won't save arrays(and that's fair enough), so that snookered that one. Smoke makes things work. When the smoke gets out, it stops! |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1145 |
What about encoding your variables into a number of strings, and a corresponding decode when reading them. Strings can be 255 character long, so 8 strings will let you use all the 2K available, and these 8 variable names should fit on the command line. So each string could be treated as an array of 255 by 8 bit integers or whatever you want(eg. 127 by 16 bit integers) . You should be good at substring(), ASC() and CHR$() when you are finished. Regards Gerry F4 H7FotSF4xGT |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6595 |
Could you put the variables into a string? Jim VK7JH MMedit |
Clever idea, fellas - thanks - never thought of that. I will look into this, but that would be a good way to do it, as ALL variables are only one byte each(control bytes for the preamp chip), so I could have a routine to build a single string consisting of the bytes I need, then read that back and decode it at powerup. Excellent idea, chums! Smoke makes things work. When the smoke gets out, it stops! |
| kiiid Guru Joined: 11/05/2013 Location: United KingdomPosts: 671 |
I think the better approach (is it possible, Geoff?) would be to have an optional type word for the variables. Something like this: DIM SAVED x, y, z DIM SAVED a(100) Then VAR SAVE and VAR RESTORE will not have any parameters. http://rittle.org -------------- |
| Lou Senior Member Joined: 01/02/2014 Location: United StatesPosts: 229 |
Grogs Wrote: The VAR SAVE command is very handy, but I have found that there is a situation where you have lots of
variables you want to save, and they cannot be fitted on the one command line. Yes, I need to save at least 200 six character numbers in variables - I could use the whole 2k. I thought about packing them into strings, but I'm not sure exactly how to do it. It would be nice to be able store them in variables like Grogs said VAR SAVE 1, VAR SAVE 2 etc. Any ideas would be helpful. Thanks, Lou Microcontrollers - the other white meat |
| Geoffg Guru Joined: 06/06/2011 Location: AustraliaPosts: 3366 |
I have just had a light bulb moment regarding how multiple saves could be technically implemented inside the interpreter. I will investigate and if it works out I will put it in the next version. Geoff Geoff Graham - http://geoffg.net |
| MikeO Senior Member Joined: 11/09/2011 Location: AustraliaPosts: 275 |
Hi I have used strings in a data backup scheme for a recent program. I needed the ability to set some defaults initially (or for a clean install) and also backup to the flash when parameter changes were made within the program. The parameters are loaded on power up or defaults set if the flash has not previously been initialized. Hope it makes some sense! 'Data Restore on power up DataRestore 'recover from data backup If Pin(pinButton)=0 Then backup=0 'force default load @ power up If backup=0 Then 'if no backup has been saved then set defaults Print "Store defaults DM$(1)="" DM$(2)=" ,Sens1,Thres,500,Norm,0,0,0,0,1,0,0,0,0,0" '14 items Sensor Mode DM$(3)=" ,0,0,0,0,Secs,0,1" '8 items DM$(4)="None,100,0,No,No,Auto,Menu" '7 items DataBackup End If Sub DataBackup backup=1 'copy array into separate strings to store to flash. DM1$=dm$(1) dm2$=dm$(2) dm3$=dm$(3) dm4$=dm$(4) dm5$=dm$(5) dm6$=dm$(6) dm7$=dm$(7) dm8$=dm$(8) dm9$=dm$(9) dm10$=dm$(10) Var save backup,dm1$,dm2$,dm3$,dm4$,dm5$,dm6$,dm7$,dm8$,dm9$,dm10$ End Sub Sub DataRestore Var Restore Print "Recover DM strings into DM Array from flash" 'Print "Backup ";backup;" DM1$ ";dm1$ dm$(1)=Dm1$ ' dm$(2)=dm2$ dm$(3)=dm3$ dm$(4)=dm4$ dm$(5)=dm5$ dm$(6)=dm6$ dm$(7)=dm7$ dm$(8)=dm8$ dm$(9)=dm9$ dm$(10)=dm10$ 'print backup;" ";dm1$ 'clear strings DM1$="" dm2$="" dm3$="" dm4$="" dm5$="" dm6$="" dm7$="" dm8$="" dm9$="" dm10$="" End Sub Mike Codenquilts |
| ajkw Senior Member Joined: 29/06/2011 Location: AustraliaPosts: 290 |
Hopefully Geoff's light bulb is bright.
I still have this same problem from here http://www.thebackshed.com/forum/forum_posts.asp?TID=7445&KW=var+save |
@ ajkw - I remember that thread. Looks like it is my time to get bitten by this particular issue. Smoke makes things work. When the smoke gets out, it stops! |
ajkw wrote: Hopefully Geoff's light bulb is bright.
I second that !! Thanks Geoff, hope your idea works. Lou Microcontrollers - the other white meat |
