Local Time 01:39 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CFunction request LIST OPTIONS
twofingers
Posted: 06:46am 17 Nov 2015
Hi all,
would it be useful and feasable to have a CFunction which list you all of your OPTION settings (the whole setup)?
This concerns to AUTORUN, LCDPANEL (pins), TOUCH (pins), CLOCKTRIM, BAUDRATE, PIN (security), CONSOLE, BREAK, EXPLICIT, DEFAULT, COLOURCODE and many more.
I think it could help to solve some issues because you can instantly see (and post into this forum) your setup. I believe it may be better this _not_ to integrate in the MMBasic code directly.
The MM code is already very complex and we need tools to handle this complexity.
The name could be CFunction List_Options (can be confused with OPTION LIST!) or List_Setup.
This is just a request for a discussion. What are you thinking?
Michael
