Local Time 01:39 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VAL in Micromite
helltek
Posted: 05:26am 15 Nov 2015
How does the "VAL" statement work in Micromite Basic?
I get ZERO value.
Text$="Test"
for i = 1 to LEN(Text$)
DA$ = MID$(Text$,i,1)
DT1 = VAL(DA$)
Print "Text$="Text$" DA$="DA$" DT1="DT1
next i
> run
Text$=Test DA$=T DT1= 0
Text$=Test DA$=e DT1= 0
Text$=Test DA$=s DT1= 0
Text$=Test DA$=t DT1= 0
Chris Roper
Posted: 05:32am 15 Nov 2015
Val converts a string into its equivalent numeric value.
Letters of the Alphabet are not Numeric so return 0.
Change your test string to Text$="1234"
and run it again you will see what I mean.
Chris
http://caroper.blogspot.com/
twofingers
Posted: 05:34am 15 Nov 2015
  helltek said   How does the "VAL" statement work in Micromite Basic?
I get ZERO value
Just try
Print val("5")
or
a$="123"
Print val(a$)
Michael
sc05027
Posted: 05:38am 15 Nov 2015
or use ASC(arg) to returns the ASCII code for the first letter in the argument
SC
helltek
Posted: 05:39am 15 Nov 2015
Thanks for quick reply.
Is there a way to get the ascii value of a text character?
twofingers
Maybe you are looking for ASC?
The Ascii value of a character?
helltek
Posted: 05:46am 15 Nov 2015
Thanks. Yes, that's what I need. The ascii value of text character. The "VAL" statement confused me thinking it would give me the ascii value.
twofingers
Posted: 05:51am 15 Nov 2015
that happens sometimes ...
Posted: 03:01pm 15 Nov 2015
I used VAL all the time by mistake when I needed ASC, if that makes you feel any better. It would seem to be a common mistake when learning.
