Local Time 01:39 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : file sizes on colour maximite
Yourock17
Posted: 12:17am 08 Nov 2015
Hey guys, is there any way to get the size of a file on the SD card as a variable while the program is running? As an example, I am trying to make a fancy .mod player and I would like to get the length of the song currently playing. I saw the LOF() function in the manual, but am unsure of it's use. Im not sure where to start or if it's even possible. Any suggestions would help.
My firmware version is 4.01 on the Colour Maximite
twofingers
Posted: 02:10am 08 Nov 2015
  Quote  Hey guys, is there any way to get the size of a file on the SD card as a variable while the program is running?
Yes!
A code snipped from my File Selector :
Dim errText$(17)
'0="No error"
errText$(1) ="No SD card found"
errText$(2) ="SD card is write protected"
errText$(3) ="Not enough space"
errText$(4) ="All root directory entries are taken"
errText$(5) ="Invalid filename"
errText$(6) ="Cannot find file"
errText$(7) ="Cannot find directory"
errText$(8) ="File is read only"
errText$(9) ="Cannot open file"
errText$(10)="Error reading from file"
errText$(11)="Error writing to file"
errText$(12)="Not a file"
errText$(13)="Not a directory"
errText$(14)="Directory not empty"
errText$(15)="Hardware error accessing the storage media"
errText$(16)="Flash memory write failure"
errText$(17)="Source and destination are the same!" 'MMBasic bug
Function FileSize N$
Local OpenError
If n$<>".." Then
Option Error Continue
Open N$ For input As #10
OpenError = MM.Errno
Option Error Abort
If OpenError Then
StatusMsg ("OpenError: "+errText$(OpenError))
FileSize=0
Else
FileSize=Lof(10)
Close 10
Else
FileSize=0
End Function
EDIT
Most of the code is errror handling. The essential part is this:
Open "YOURFILE.MOD" For input As #10
FileSize=Lof(10)
Close 10
EDIT2
  Quote  My firmware version is 4.01 on the Colour Maximite
I can strongly recommend that you upgrade to 4:05 (MMBasic 4.5). It's easy to do.
MichaelEdited by twofingers 2015-11-09
Yourock17
Posted: 02:54am 08 Nov 2015
Thanks for the help, however it errors as "Must be an open COM port". I have no idea what this means. I will update the firmware soon.
