Forum Index : Microcontroller and PC projects : Micromite 5.0
| Page 1 of 4 |
I have finalised the Micromite 5.0 firmware (for the MX170 chips) and it can be downloaded from: http://geoffg.net/micromite.html#Downloads This is essentially the same as beta 37 with a few minor changes: - Weak pullups can be specified on the I2C data and clock lines by appending the option ", PU" to the end of the I2C OPEN command. I2C normally requires lower value pullups but for short signal lines at slow speed this may be all that is required. - Internal pullup resistors (100K) are automatically applied when the RTC commands are used. In many cases this removes the need for external pullup resistors. - Added OPTION RESET command to quickly reset all saved options to their initial default values. - Added MM.FontHeight and MM.FontWidth to the MX170 version. - Added two embedded C modules (CFunctions) for creating multiple I2C and SPI interfaces. - Fixed a bug which caused the PULSE command to throw an error when PULSE pin, 0 was used to terminate a currently running pulse. Thanks very much to all the good people that tested and played with the beta versions. There were numerous bugs in there that I would not have found on my own and your efforts have made a huge difference to the quality of this release. Also great thanks to Peter Mather for showing that LCD panels can be driven by a Micromite and MMBasic, the ILI9341 driver and the many bugs that he found (and fixed). Without his trailblazing efforts the Micromite would still not have support for LCD display panels. I have to do some more work on the Micromite Plus version so it will be about a month before I can release a final version of that. Geoff Geoff Graham - http://geoffg.net |
WOW! This is fantastic, Geoff! Micromites and Maximites! - Beginning Maximite |
Brilliant stuff
Am liking the OPTION RESET and Font Height & Width features Thanks for this . . . |
| viscomjim Guru Joined: 08/01/2014 Location: United StatesPosts: 925 |
Hi Geoff, did you happen to find the bug (and fix) with the Com 2 problem? This is important for me on a particular project. Thanks for all your hard work!!!!! |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1783 |
Thanks Geoff, the both Peters (Matherp & G8JCF) and all the fine people which helped developing this piece of code.
It was a long long way! Hard work! Geoff, please update your download page But it is actually V5!
Kind regards Michael |
http://www.thebackshed.com/forum/forum_posts.asp?TID=8046&PN=2&TPN=4 This is the issue I mentioned earlier. Thanks again!!!! |
| Justplayin Guru Joined: 31/01/2014 Location: United StatesPosts: 330 |
Thank you Geoff! How did you know I wanted more SPI interfaces? How can you beat getting a feature added before you even asked for it or really knew you might need it! --Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
Yes, the Com 2 problem should also be fixed. For some reason my website is down. I have contacted the hosting company so hopefully it will be fixed soon. EDIT: Back online again. @twofingers, you need to refresh your browser's cache. Geoff Graham - http://geoffg.net |
Probably 'crashed' with the high volume of visitors wanting to download v5 |
| kiiid Guru Joined: 11/05/2013 Location: United KingdomPosts: 671 |
Excellent!! Looking forward to the MM+ 5.0 version, just in time for presenting my stuff...
http://rittle.org -------------- |
@Geoff, you are right, sorry! |
| OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 1056 |
Geoff, Can we still load this version onto a 270 chip with the loss of the two pins? GM |
Graeme, yes you can. It even knows that you are running on a MX270 and will throw an error if you try to use the pins assigned to USB. Geoff Graham - http://geoffg.net |
Thankyou Geoff, your efforts are well appreciated here. |
| piclover Senior Member Joined: 14/06/2015 Location: FrancePosts: 134 |
Greetings Geoff, Well done with v5.0, however it looks like you did not update the source files download site: I requested the sources for Micromite MMBasic and got v4.6's instead of 5.0's... Can you please fix this ? Thank you ! :-) |
@piclover, Is this just another case of needing to clear your cache first? Only suggesting it as it may solve your issue . . . WW |
I have not updated the source yet for a couple of reasons. First, I have not finished the MX470 (MM+) version and the two are entwined in the one source tree and secondly I need to do some work cleaning up the code. If it is important to you I can send the current version to you (send me an email, not a PM) but it will not be the same as the eventual final version. Geoff Geoff Graham - http://geoffg.net |
Email sent. Thank you ! |
| PicFan Senior Member Joined: 18/03/2014 Location: AustriaPosts: 133 |
Hello Geoff and Peter Mather ! Many thanks from Austria for this great work, FANTASTIC !!! Thank you !! Erwin, Günter and Wolfgang |
| f1fco Senior Member Joined: 18/03/2012 Location: FrancePosts: 155 |
a very BIG thank from France also Pierre, F1FCO 73s de F1FCO |
| Page 1 of 4 |
