Local Time 00:47 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Tera Term
palcal
Posted: 11:43am 23 Oct 2015
Can anyone point me to the post about modifying Tera Term so that it restarts and also the problem of font too large.
Paul.
Posted: 12:10pm 23 Oct 2015
Is this what you were after:
http://www.thebackshed.com/forum/uploads/robertrozee/2015-08-04_094221_Easy_reconnect_of_USB_port_to_TeraTerm_after_clie nt_reset.pdf
Not sure about the 'font too large' issue. You can configure TeraTerm with any font size that suits.
Zonker
Posted: 12:36pm 23 Oct 2015
@Paul.. I think the "font to large" thing was a firmware bug... Did you bump up to the current release from Geoff..?
palcal
Posted: 02:24pm 23 Oct 2015
Thank Jim, thanks Zonker still running v23 will update.
Paul.
isochronic
Posted: 02:42pm 23 Oct 2015
It should be pointed out, that it is a security hole.
The (historical) idea of not reconnecting after a serial connection has dropped out, is to prevent third parties interceding. If reconnection is automatic without warning, the operator does not know if a connection has dropped out (ie cut) and reconnected to a different party.
