Local Time 23:54 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : loading of constant arrays
kiiid
Posted: 11:51pm 18 Oct 2015
How can a long constant array be loaded with data?
I tried with adding the values in a few lines, but it doesn't work and generates an error "expecting a closing bracket" at the end of the first line.
Loading from DATA is also not an option because is it constant.
Edited by kiiid 2015-10-20
http://rittle.org
Posted: 11:53pm 18 Oct 2015
At the moment arrays of constants are not possible.
If you are talking about initialising an array variable the initialising values must be on the one line (max 255 chars).Edited by Geoffg 2015-10-20
