Local Time 23:05 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help needed: MM+ FILES fspec$
Posted: 10:50pm 17 Oct 2015
Please can anyone with a MM+ setup try the FILES fspec$ command for me.
Whenever I try it I get a '0 directories, 0 files' message displayed. However, the FILES command by itself works fine.
I have tried this on an Explore64 module (B36) and a custom setup based on a 64pinner with ILI9341 (touch) and separate SD card socket ((under B37).
I am using a 2G Kingston card that saves and loads without fail. But whenever I specify *.*, or *.BAS, or *.BMP, I never see a list of files.
Any help would be appreciated. If you can post your setup info and Beta version too it will help track down the issue
Many, many thanks to you all . . .
WW Edited by WhiteWizzard 2015-10-19
Greg Fordyce
Posted: 12:11am 18 Oct 2015
Using beta 37 I can't get it to work with the fspec option either.
> files
<DIR> DEMO
<DIR> MMEDIT
<DIR> TRASH-~1
11750 CELLII.CSV
696 NAME.BAS
802 NAME2.BAS
5272 PUMPDEMO.BAS
35 RS.CSV
6453 TEST.CSV
7182 TESTER1.BAS
7282 TESTER14.BAS
7536 TESTER2.BAS
7182 TESTER3.BAS
3 directories, 10 files
> files "*.*"
> files *.*
Posted: 12:17am 18 Oct 2015
Bug confirmed
Posted: 01:04am 18 Oct 2015
Thanks - that solves one of my two issues
Posted: 01:48pm 18 Oct 2015
Confirmed here too.
Posted: 04:34pm 18 Oct 2015
Thanks folks, it will be fixed in the next beta.
