Local Time 23:05 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM and watchdog
Chrisk
Posted: 08:29pm 12 Oct 2015
Hi Guys
I wish to use the watchdog command to restart a program should it get itself into a loop or some sort of program failure.
I have the watchdog instruction in a section of the program which is named autorun.bas
What what do I place in restart.bas
I tried the one line: run autorun
but it didn't seem to restart when it crashed.
Have I got this correct.
From what I can gather from The Back Shed forum that is all I need.
I have a CMM running Ver 4.5 with both files on the b: drive (SD card)
Chrisk
Posted: 09:06pm 12 Oct 2015
Hi Chrisk,
Not too sure on this one but does your one-line need to include quotes?
So restart.bas contains: RUN "autorun.bas"
No doubt someone will chime in here too to prove me wrong!
WW
Start with a PRINT "OOPS!!!"
in the restart.bas file so you know that you got that far.
I think you need quotes around the file name for the RUN command
run "autorun.bas"
Edited by TassyJim 2015-10-14
Chrisk
Posted: 04:46pm 13 Oct 2015
Thanks WhiteWizard and TassyJim.
It was those double quotation marks that were required.
Not sure why they are needed but it worked.
For future reference I should point out I was using TeraTerm and when restart.bas ran the USB communications no longer existed. So no "OOPS!!!" was viewed.
The main thing is I saw that the main program restart.
I gives me that confidence that it will restart should I not be in attendance.
You where a great help.
Chrisk
Greg Fordyce
Posted: 08:53am 14 Oct 2015
The double quotes tell the MM that "autorun.bas" is a string and not a variable.
You could also define a string variable to use instead.
A$ = "autorun.bas"
Run A$
