Local Time 22:02 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [MMBASIC]Const arrays
Greg Fordyce
Posted: 09:27am 26 Sep 2015
@Geoff
Would it be possible to extend the CONST command to include arrays?
For example;
CLS
Option base 1
Const cellid(6) = (4,5,6,7,8,9)
For i = 1 To 6
GUI textbox cellid(i), 5+(i-1)*133, 85, 120, 50, RGB(red), RGB(gray)
Next i
At the moment I can use this, but I want to be able to refer to the controls in a FOR/NEXT loop as well. Because cellid is a variable there is a risk it could be inadvertently change;
CLS
Option base 1
Dim cellid(6) = (4,5,6,7,8,9)
For i = 1 To 6
Next i
Posted: 12:16pm 26 Sep 2015
It should be possible (and easy) because constants and variables are closely related and share a lot of the same code.
I will investigate.
