Local Time 21:03 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Open # Error
jman
Posted: 10:22pm 06 Sep 2015
Hi
I am not sure if this is a bug or have I missed something
Could somebody please try the code below and see if they get an error
after the 1st pass. As you can see the #1 is never closed but it seems the
close #2 closes all open ports / files
"[19] Do : Loop Until Input$(255, #1) = ""
Error: File number is not open"
I have attached the file that is read from the SD card
Open "Com1:38400, 20480" As #1
Start:
Clearbuffer
Open "icons1.dat" For Input As #2
For I = 1 To 38
Line Input #2, Test$
Print Test$
Next I
Close #2
Goto Start
' Clear the serial input buffer
Sub ClearBuffer
2015-09-07_082000_icons1.zip
Posted: 10:40pm 06 Sep 2015
It was too difficult for me to get access to the SD card so I opened a file that was on it.
Didn't have any text files so I just did a pause after opening.
This was run OK on a uM+ with beta23
Start:
Clearbuffer
Open "img_20~1.jpg" For Input As #2
pause 2000
Close #2
Goto Start
Sub ClearBuffer
print "OK"
jman
Posted: 07:31pm 07 Sep 2015
Hi
Ok more weird stuff
If I run the code below it stops with a = 1
no changes type run again and it works fine
So some thing odd going on here
> run
1
[20] Do : Loop Until Input$(255, #1) = ""
> run
1
2
3
4
5
6
Start:
Clearbuffer
Pause 500
Close #2
A=A+1
Print A
GoTo Start
Sub ClearBuffer
Any Help appreciated
Jman
Posted: 07:44pm 07 Sep 2015
John, I plan to test this when I rebuild my test setup. It may take a few days.
jman
Posted: 07:53pm 07 Sep 2015
Thanks Geoff
Posted: 10:45pm 19 Sep 2015
Finally I found it.
It was very subtle, this just shows the benefit of beta testers playing with early versions as I would never have found it normally. It depended on the sequence that the COM ports and files were opened. Thanks also for an excellent demo of the fault, that helped enormously.
The fix will also be in the next publicly released beta.
