matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12074
Posted: 11:22pm 28 Aug 2015
Should be fine, looks exactly like the one I have.
The only issue with this version is that it gets the power for the backlight off the 3.3V supply so you need to make sure your 3.3V regulation is adequate (the LED pin is only used as a switch for the backlight).
I find the display is rather dim, certainly not as good as either my 4.3" or 7" displays.Edited by matherp 2015-08-30
f1fco Senior Member Joined: 18/03/2012 Location: FrancePosts: 155
Posted: 04:06am 29 Aug 2015
what is the "right" model ?
with external power supply (5v ?) for the back light
