Local Time 19:45 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Font is to large... error
Zonker
Posted: 05:14pm 27 Aug 2015
Good evening Gents...
I came across this when playing around with the GUI Display box command.. I used font #6 on a 2.4" display to get a "big" number, with box size to hold it... It looked ok, but wanted to make small position changes, so I going back to the on board editor to do the fiddling, when this error came out...
>edit
"Font to Large"
Type in "edit" and it wont start... So, after rebooting, all OK and I removed the "font #6" part and no more error... The command to create the object and data passed to it seemed to work ok, but somehow causes this lockout...
BTW.. Running on the 470 GCmicroboard with b23 release
Code "snippet"
Const system_data_frame=42
Const bat_data_box=43
Const rpm_data_box=44
Font #5,1 ' mid sized bold
GUI frame system_data_frame,"SYSTEM",190,75,125,159,RGB(yellow)
Font #6
GUI displaybox bat_data_box,195,90,MM.FontWidth*4,MM.FontHeight*2,RGB(red),RGB(black)
CtrlVal(bat_data_box)="13"
Is it just me, or has anyone else had this pop up...?
Just wondering...
Posted: 05:18pm 27 Aug 2015
Yes, it is a known bug.
You have to issue FONT 1,1 and enter, THEN you can call the editor.
Geoff knows about this one, and is on his to-do pile for when he is back home.
