Local Time 19:44 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LCD text
jman
Posted: 09:25pm 22 Aug 2015
Hi All
Using a MM+ with a colour LCD I would like to use the Text command
without it using a background colour.
I have a BMP for the background and would like to overlay the text on the bmp
without the text setting its own background colour
Is this possible ?
Jman
Posted: 01:27am 23 Aug 2015
  Quote  Is this possible ?
Not without some significant changes to the firmware. The way it works is that a display region is created the size of the character, the software then clocks through the character's bitmap and either sends the foreground or background colour without having to do any further pixel positioning
To do what you want the firmware would need to send each foreground pixel individually and re-position over each background pixel. This would be much slower.
It could be done in a CFunction but it would be a pretty complex one and not fast
