Local Time 19:04 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C Pins on the Explore64
atmega8
Posted: 09:47pm 17 Aug 2015
Oh, ahhhrgghh...
No, it is PIN 43 data and 44 clock !!!!
My ds3231 is working now ;-)
Found it PIN 32 and 31 !!!
Sorry
Hi Grog,
where can i find the I2C pins on your board?
The Microchip manual shows pin 36 for SDA1
and pin 37 for SCL1, but i can't find this pin numbers on the silkscreen.
Edited by atmega8 2015-08-19
Posted: 10:15pm 17 Aug 2015
I2C - pins 43(SDA) and 44(SCL).
Manual, page 11 for pinout of the E64.
EDIT: First Jim, now YOU beat me too it! Well done. Yeah, I think the pin assignments changed around a bit in the early alpha versions - not sure if you were involved in that or not. The PDF manual in the download from Geoff's site lists the correct current pinouts.Edited by Grogster 2015-08-19
