Local Time 19:03 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Newbee firmware upgrade question?
MMAndy
Posted: 08:11am 12 Aug 2015
New bee firmware upgrade question?
I have the latest MPLAB IDE v3.05 and a Pickit 3 clone. (Olimex)
Under MPLAB, I imported the latest firmware hex Prebuilt (Hex, loadable Image) project - MM+ firmware release V4.7B23. This hex file is 1,335 KB.
Under MPLAB, I read the PIC32MX470F512H device memory to file. This hex file has 1,474 KB.
There is a small difference in both files. Is this correct?
Do I need to set the config. bits?
Note: Both hex files have 131,072 for data and 536560 for program.
Note: I did NOT use the PICkit 3v3.10 standalone program because the "470" device file is missing.
I chose to import a hex firmware file in the IDE then re-program a device with it.
System: PC/Win/8.1Edited by MMAndy 2015-08-13
Posted: 08:48am 12 Aug 2015
After burning a new chip with the Micromite firmware, the first thing it does when run is initialise the options which are stored in flash memory. For this reason a hex file read from the chip will be very slightly different from the hex file you program.
Was that the question?
MMAndy
Posted: 08:50am 12 Aug 2015
  Quote  Was that the question?
Yes, ThanksEdited by MMAndy 2015-08-13
MMAndy
Posted: 10:15am 12 Aug 2015
It would be convenient for users for a new command like "OPTION LIST" to indicate
what option PINs are being used along with which options that are enabled or disabled or default.
Bryan1
Posted: 12:44pm 12 Aug 2015
Hi Andy,
The easiest way I have found to load new firmware into the pic is using the MPLab IPE software that come with MPLab. Just pic the model of pic micro then go to advanced and select the hex you want and program it. Too easy.....
Regards Bryan
MMAndy
Posted: 02:18pm 12 Aug 2015
  Quote  Just pic the model of pic micro then go to advanced and select the hex you want and program it
  Quote  Note: I did NOT use the PICkit 3v3.10 standalone program because the "470" device file is missing. I chose to import a hex firmware file in the IDE then re-program a device with it.
