Local Time 17:49 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Future OPTION from MM+ Explore 64 SD?
MMAndy
Posted: 05:13pm 04 Aug 2015
Future OPTION(s) setup from MM+ Explore 64 SD module?
I know you can only do OPTION(s) commands from the command prompt not by the program user code.
If the user has a "fixed" keyboard, sounder/buzzer, TFT SSD1963 LCD display with touch connected to the MM+ Explore 64, wouldn't it be easier to read all the OPTION(s) commands from the MM+ Explore 64 SD card? This way, no PC console would be required on a fixed peripheral configuration like a portable MMBasic laptop.
Note: This would require the MM+ Explore 64 SD OPTION to be already configured and setup.
Note: By grounded GPIO pin could activate this process?
Posted: 06:55pm 04 Aug 2015
Most options are remembered so they only need to be set once.
No need to read them from a SDcard.
Many of the options also required a reboot so reading them automatically would be tricky. Continual reboots etc.
Posted: 07:01pm 04 Aug 2015
I agree with Jim.
I like the idea, MMAndy, but as Jim says - the killer is really the fact that those options need you to restart MMBASIC. Still, it's a nice idea.
Posted: 07:07pm 04 Aug 2015
If you are looking at producing large numbers, you can configure one, read the program using MPLAB and then use that HEX to program the rest of the batch.
The procedure to do that has been discussed here recently.
Posted: 07:39pm 04 Aug 2015
EXCELLENT idea, Jim - should have thought of that!
MMAndy
Posted: 02:30am 05 Aug 2015
  Quote   you can configure one, read the program using MPLAB and then use that HEX to program the rest of the batch.
My first goal is eliminate using a PC to configure the MM+ Explore 64 and my
second goal, which is extremely farfetched, is to come up with a solution to update the firmware/user application code without using a Pickit3 and/or PC. Think of it as a "black box" with a SD card and a hex file containing the firmware and application code which programs the MM+ Explore 64 stamp module without a PC.
Edited by MMAndy 2015-08-06
Posted: 03:08am 05 Aug 2015
@MMAndy
Hint: PTG from a PicKit3 - Is the method I am using, and works a charm! I think you may have the same end goal as me requiring a number of MM+ 'gadgets' to be programmed with the same firmware & 'option settings'.
By the way your Explore 64 fully Assembled module was despatched yesterday (UK Tuesday).
WWEdited by WhiteWizzard 2015-08-06
