Local Time 19:06 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Using MMBasic as shell
isochronic
Posted: 06:59pm 02 Aug 2015
Hi
Would it be realistic to adjust the MMBasic prompt environment to be a sort of shell or OS ? It looks good and it has a lot of nice features, I am wondering if CFunctions can run "underneath" then maybe a CFunction could run as its own simple application ? I am probably way off track so apologies if that is so ( wouldn't be the first time :) )
G8JCF
Posted: 01:57am 03 Aug 2015
It will be possible to do what you want in the very near term, just not right now
PeterEdited by G8JCF 2015-08-04
The only Konstant is Change
Chris Roper
Posted: 03:44am 03 Aug 2015
  chronic said  Would it be realistic to adjust the MMBasic prompt environment to be a sort of shell or OS ?
I would love to see a simple Line Edit function where Up Arrow is last command and then you can modify it into a new or corrected command.
http://caroper.blogspot.com/
G8JCF
Posted: 11:52am 03 Aug 2015
@chronic
You're not off track at all !
In 4.7 B23 and later there is a way for a CFunction to run in the background all the time even when MMBasic is sitting at the command prompt.
goto http://www.mmbasic.org/calltable/CFuncmSec.html for documentation and example code.
Notice that if you break out of the program using Ctrl+C, the background CFunction continues to run.
CFuncmSec is the gateway to providing time-slice multi-tasking (of C code only) under MMBasic
Peter
isochronic
Posted: 02:55pm 10 Aug 2015
It raises another question, can a CFunction (or similar) run
in other (within reason!) environments ? I gather it is a slab of largely
autonomous machine code ? The SD card Cfunction looks really nifty
G8JCF
Posted: 03:01pm 10 Aug 2015
Thank you @Chronic
The SDCard driver is closely integrated with the MMBasic Interpreter and could NOT run in any other C environment.
Peter
