Local Time 17:50 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C Read to array problem
Bizzie
Posted: 08:02pm 31 Jul 2015
Hi all,
Has anyone tried reading a single byte of data into an array element?
I have a CGColorMax2 updated to "Colour Maximite MMBasic firmware V4.5" hooked up to one of BigMik's I/O panels by I2C (pullups enabled on panel).
Running the following code with variable t = 0 results in all 0's regardless of what pins of the PCF8574 IC are held high.
Changing the variable t = 1 all is fine!
' Test I2C
I2C open 100,500
I2C write &H20,1,1,0
Dim d1(2)
Pause 100
t = 1
If t=0 Then
I2C read &H20,1,1,d1
Print MM.I2C,"==>",d1(0)
Else
I2C read &H20,1,1,d
Pause 500
Anyone see what I am doing wrong? 0r Have I stumbled across a bug?
Rob
Rob White
BobD
Posted: 08:35pm 31 Jul 2015
What about this
[code]
If t=0 Then
I2C read &H20,1,1,d1(0)
etc
[/code]
you have created an array but when you use it you haven't said where you want to put the data. D1 without the array index would just be another variable but not your array.
Bizzie
Posted: 09:14pm 31 Jul 2015
Thanks BobD,
Knew it would be simple got a feeling my VB programming may of got in the way there!
Rob White
