Local Time 17:00 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : a small bug in 4.7 beta 8
Posted: 02:19am 17 Jul 2015
i'm not sure if this bug has been raised before:
i = Val("+3")
Print i, "val() is ok"
Pause 1000
i = +3
Print i, "direct is ok"
Pause 1000
3 val() is ok
CPU exception #7 (bus error on load or store) at address 0x9D010D68
Processor restarted
rob :-)
Posted: 02:51am 17 Jul 2015
Thanks Rob, I will have a new beta for the Mx170 in a couple of days and the fix will be in that.
Posted: 05:38am 17 Jul 2015
another small bug i am afraid!
while editing a program that is well over a page long, use f4 to mark and cut out a few lines near the top of the code. now press down-arrow to move the cursor to the bottom of the remaining code. when it gets to the end of the code, the last line will not be displayed, and the cursor will move to the bottom right of the terminal screen (the end of the status line).
rob :-)
atmega8
Posted: 05:44am 17 Jul 2015
  robert.rozee said   another small bug i am afraid!
rob :-)
IS The line Buffer of your Terminal Programm big enough?Edited by atmega8 2015-07-18
Posted: 01:14pm 17 Jul 2015
Thanks Rob, that one is more difficult so I will have to add it to the list for later.
