Local Time 19:45 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Interesting multi-function USB host
Posted: 07:05am 15 Jul 2015
Just found this
I have no information other than that on the website but it looks like a great way to interface specific USB devices to a MM2
The various software modules are uploaded using a bootloader (DS30) which I have used before and this means no programmer (PicKit etc.) is needed to swap between the various images
CircuitGizmos
Posted: 07:36am 15 Jul 2015
I have one of those, but I have not put it to use yet.
plasma
Posted: 09:45pm 15 Jul 2015
Great info , thx matherp
Posted: 09:55pm 15 Jul 2015
By the way, these guys also supply a lower cost pre-programmed PIC chip by itself for use on your own PCB/breadboard. Available in DIP, SOIC, and SSOP packages.
To view details about these, click on matherp's link in the original post above, then on the HobbyTronic's page, click 'Related Products' and scroll down . . .
PS - The guys are one of my regular suppliers and I find their products very good quality
Posted: 10:30pm 15 Jul 2015
It is a great gadget. This is one of these times whn I say to myself "why didn't I think of that".
Posted: 02:24am 16 Jul 2015
Perhaps this could be the solution to the USB Keyboard concept that was floating around the threads for the MM+?
Chris Roper
Posted: 02:34am 16 Jul 2015
Or a Micromite implementation on the PIC270MX with the different USB modes loadable via CFunctions.
http://caroper.blogspot.com/
BobD
Posted: 02:35am 16 Jul 2015
  Grogster said   Perhaps this could be the solution to the USB Keyboard concept that was floating around the threads for the MM+?
that's what I thought when I first read about it but it ends up being expensive. The card would probably cost AU$35 to 40 landed in OZ then you need a keyboard.
Chris Roper
Posted: 02:36am 16 Jul 2015
Or a Micromite implementation on the PIC32MX270 with the different USB modes loadable via CFunctions.
EDIT: Duplicate due to Internet error, my apologies, I can't even edit the erroneous post above.Edited by Chris Roper 2015-07-17
BobD
Posted: 02:49am 16 Jul 2015
Chris, It's a forum implementation that edit capability is closed when there is a subsequent posting.
Bob
Posted: 02:53am 16 Jul 2015
Hmmmmmmm..............good point........
Perhaps not.
BobD
Posted: 02:59am 16 Jul 2015
I just took that card to the checkout and it was AU$42.60 delivered and then there would be card or Paypal fees on top. So looking like $45 all up.
Posted: 05:24am 16 Jul 2015
  Quote  So looking like $45 all up.
Sounds like WhiteWizzard micromite.org has a relationship with the supplier. Why not PM him to see if he can do something on postage and/or bulk shipping
Positron
Posted: 04:37pm 13 Aug 2015
Hi all !, I bought the HobbyTronics USB Host Keyboard to Serial chip in DIP package and works ok for standard ASCII input, I' m using it with a wireless mini keyboard. The problem arises when you try to use it as the Console input, as it does not implement the proper VT100 escape sequences recognized by the MMite built-in Editor ( arrow keys, function keys, etc).
So it doesn't work as a full PS/2 keyboard replacement
The firmware is not open source and the key mappings are not user reconfigurable, at least in the current version. As Grog suggested in another post adding a simple PIC with a serial- in serial-out translation table could solve the problem, but in the end it will be a 3 chip solution, kinda' overkill !
boss
Posted: 05:28am 15 Aug 2015
Good morning Gents,
I purchased roughly 9 month ago similar (if not the same) device on eBay for $10. The device was made by renowned Chinese company so I didn't expect any serious problems. The reality was shocking. Only what works was read/write to USB stick, but there was stick capacity limit (I think 4GB max) if I remember well. Unfortunately very limited number of Dell and HP keyboards and mice was properly recognized. Btw I received full source code written by Microchip, but in C and buggy. If someone is interested in the source code I could to find it.There was also enclosed a written permission to change and modify this source code. I believe that source code origin might be Microchip library.
Bo
Positron
Posted: 08:12am 15 Aug 2015
  boss said   Good morning Gents,
... Btw I received full source code written by Microchip, but in C and buggy. If someone is interested in the source code I could to find it.There was also enclosed a written permission to change and modify this source code. I believe that source code origin might be Microchip library.
Bo
Hi Boss, I could check that source and see I can remap the escape codes , could you Send me a link, Thanks !
boss
Posted: 09:35am 15 Aug 2015
@Positron
I'll do it ASAP and send the file to you via PM.
Bo
Chris Roper
Posted: 10:55am 15 Aug 2015
Sounds interesting, I have a few PIC24FJ64GB002's sitting on my bench and would love to try the code.
I am not much good with C though so may have to wait and see what Positron can do with it.
I had a look at the Microchip Library's but, as with most Microchip Documentation, the comments were way over my head and the code somewhat obfuscated at times.
Chris
boss
Posted: 11:05am 15 Aug 2015
@ Chris Roper
Neither I am. I think this is challenge for some of C gurus on this forum. If you are interested in code, please send message with your email address to my PM.
Bo
