Local Time 16:13 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : FreeTronic OLED
marcwolf
Posted: 03:51am 02 Jul 2015
Hi Folks.
I was wondering if someone has used one of these with a Maximite or Micromite
OLED
My project needs me to load up a bitmap to an OLED, and speed is required.
Many thanks
Dave
Coding Coding Coding..
Keep those keyboards coding..
RAW CODE!!!!!
Posted: 04:04am 02 Jul 2015
This code should support it.
I haven't updated this for some time but if you actually start using it let me know and I'll bring the code up to current spec.
The code works as-is on 4.6
To use on 4.7b8 add the following line after the SPI OPEN command
poke word &HBF805830,1
this fixes a SPI bug in 4.7b8Edited by matherp 2015-07-03
Posted: 06:51am 02 Jul 2015
Peter,
Is this the same code that you initially did for the OLED I sent you? If so, an update would be appreciated
WW
jman
Posted: 07:43pm 02 Jul 2015
  WhiteWizzard said   Peter,
WW
What he said :)
Jman
Posted: 11:54pm 06 Jul 2015
  Quote  Is this the same code that you initially did for the OLED I sent you? If so, an update would be appreciated
Yes it is.
Update posted in the general update thread
