Local Time 15:30 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : touch buttons
palcal
Posted: 07:29pm 28 Jun 2015
I am upgrading a project to use a 2.8" TFT display. I have the display working OK and have set up the display the way I want. Previously I had 3 switches connected to interrupt pins. I now have 3 touch buttons on the screen, how do I monitor the buttons. I looked through Peter's demo code but couldn't find anything.
I know Geoff used the Touch(x) command but his small demo code ran so fast the touch could not be missed. With a large program it would almost certainly be doing something else during the touch.
PaulEdited by palcal 2015-06-30
viscomjim
Posted: 03:19am 29 Jun 2015
Palcal, I recall seeing a post i believe it was from Zonker where he had a gauge set up on the lcd and it had a couple of buttons, that when you touched them they turned a different color. I can't find the thread now but may look around, I thought is was pretty cool and might help you.
CircuitGizmos
Posted: 04:43am 29 Jun 2015
Make a timed interrupt (Settick) and call touch. If x and y are -1 there has been no touch.
SETTICK 100, TouchInt, 1
TouchInt:
' Read touch
tX = TOUCH(X)
tY = TOUCH(Y)
' Test for valid touch
IF tX <> -1 AND tY <> -1 THEN
IF 8 < tX AND tX < 55 AND 56 < tY AND tY < 102 THEN
keypress = 1
ELSE IF 8 < tX AND tX < 55 AND 120 < tY AND tY < 165 THEN
keypress = 2
ELSE IF 8 < tX AND tX < 55 AND 185 < tY AND tY < 230 THEN
keypress = 3
ELSE IF 71 < tX AND tX < 119 AND 56 < tY AND tY < 102 THEN
keypress = 4
ELSE IF 71 < tX AND tX < 119 AND 120 < tY AND tY < 165 THEN
keypress = 5
ELSE IF 71 < tX AND tX < 119 AND 185 < tY AND tY < 230 THEN
keypress = 6
ELSE IF 135 < tX AND tX < 182 AND 56 < tY AND tY < 102 THEN
keypress = 7
ELSE IF 135< tX AND tX < 182 AND 120 < tY AND tY < 165 THEN
keypress = 8
ELSE IF 135 < tX AND tX < 182 AND 185 < tY AND tY < 230 THEN
keypress = 9
ELSE IF 200 < tX AND tX < 245 AND 56 < tY AND tY < 102 THEN
keypress = 10
ELSE IF 200 < tX AND tX < 245 AND 120 < tY AND tY < 165 THEN
keypress = 11
ELSE IF 200 < tX AND tX < 245 AND 185 < tY AND tY < 230 THEN
keypress = 12
ELSE IF 265 < tX AND tX < 308 AND 56 < tY AND tY < 102 THEN
keypress = 13
ELSE IF 265 < tX AND tX < 308 AND 120 < tY AND tY < 165 THEN
keypress = 14
ELSE IF 265 < tX AND tX < 308 AND 185 < tY AND tY < 230 THEN
keypress = 15
ELSE
keypress = 99
ENDIF
PRINT "key: " keypress
' Turn off TouchInt
SETTICK 0, 0, 1
ENDIF
IRETURN
From that bit of code the screen is divided into 15 parts/buttons. A touch sets keypress to a key value for the main program to deal with.
palcal
Posted: 11:11am 29 Jun 2015
Thanks, I understand that, will give it a go
I would also like to thank Geoff and especially Peter for his work on the TFT displays they make a project very professional. When I built my Maximite some years back I never thought it would come to this and with the 470 maybe on the horizon who knows?
Thanks to all.
Paul.
Zonker
Posted: 04:19pm 29 Jun 2015
Evening Gent's...
Just got back to the house...
2015-06-30_021427_2-4_inch_volt_meter_demo.zip
The way I did it, was to keep the button sensing in the main "DO" loop going as fast as it can. When a touch is detected, you must loop waiting for the "no finger" response... That's where I turn the button a different color... Anyway, I guess there are several ways to get the job done... The demo was just to show the display doing something useful...
palcal
Posted: 06:43pm 29 Jun 2015
Thanks Zonker, I went with Gizmo's code and it works well.
Thanks all
Paul.
