Local Time 15:31 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2: Cfunction to read reference voltage
Posted: 06:43am 14 Jun 2015
I think Geoff is correct to remove the pin(0) syntax as it seems to be unreliable on the MX170. Also, on the MX470 it doesn't work at all (this is in the chip errata documentation).
However, for those of you who want it, here is a Cfunction to do it for you The usage should be obvious from the example code but ask any question as required. The CFunction code reads the reference voltage 9 times at 1msec intervals and throws away the first reading which often seems to be erroneous. It then averages the other 8 readings.
To make things even easier it also returns the scale factor to apply to an ADC reading to correct it for VCC
option default none
option explicit
dim integer adccount
dim float measuredref,scalefactor
const adcpin=23
setpin adcpin,ain
do
adccount=readref(scalefactor) 'read the reference voltage
measuredref=adccount/1024.0*3.3
print measuredref, scalefactor
print pin(adcpin)*scalefactor ' prints corrected voltage
pause 1000
LOOP
end
' reads the internal reference voltage
' function returns the ADC count for the reference voltage
' also the float parameter is updated with the scale factor to use for correcting any ADC readings
' i.e. scalefactor * voltage read = true voltage
CFunction readref
00000000
27bdffc8 3c029d00 8c420004 34038013 afa40038 3c04bf81 ac83a000 afbe0030
afb7002c afb60028 afb50024 afb40020 afb3001c afb20018 afb00010 240403e8
afbf0034 0040f809 afb10014 3c021000 3c03bf88 ac621064 3c04bf88 34028000
3c03bf81 ac801068 24140001 00008021 ac629004 3c13bf88 3c1e000e 3c17ffff
34168f00 3c121000 3c151000 3c04bf81 3c02bf88 ac9e9040 3c03bf88 ac406118
3c04bf81 3c02bf81 ac606108 ac979050 3c03bf81 ac569020 24020003 ac629010
3c04bf81 240200e4 ac829000 3c03bf81 34028000 ac629008 8e621030 00521024
1040fffd 3c04bf81 8c829070 02028021 24020001 12820030 3c029d00 3c119d00
8e220004 3c03bf88 ac751034 0040f809 240403e8 2a820009 1440ffdc 26940001
3c021000 3c04bf88 ac821064 3c02bf88 8e320064 3c03bf81 ac401068 3c04bf81
34028000 ac629004 ac80a000 3c08453a 35082e8c 01009821 0010a7c3 8e220080
02002021 0040f809 02802821 00402821 0240f809 02602021 8fa30038 8fbf0034
ac620000 8fbe0030 001010c3 02801821 8fb7002c 8fb60028 8fb50024 8fb40020
8fb3001c 8fb20018 8fb10014 8fb00010 03e00008 27bd0038 8c420004 3c04bf88
ac951034 0040f809 240403e8 00008021 1000ffae 26940001
End CFunction
Edited by matherp 2015-06-15
Chris Roper
Posted: 07:33am 14 Jun 2015
That looks excellent matherp, Thanks, I will give it a try.
Chris
http://caroper.blogspot.com/
viscomjim
Posted: 01:16am 15 Jun 2015
Excellent work Matherp. There seems to be no limits to what can be added using Cfunctions. Thats a good thing especially in situations like this.Edited by viscomjim 2015-06-16
G8JCF
Posted: 06:49am 15 Jun 2015
The first draft of V2.0 of the CFunctions tutorial together with V2.0 of CFuncgen itself are available for download from http://www.cfuncgen.dyndns.org/
V2.0 of the tutorials document includes a new chapter "C for MMBasic programmers" which tries to help MMBasic programmers get into C from a CFunction writing perspective.
Peter
The only Konstant is Change
Posted: 07:30am 15 Jun 2015
Here is the CFunction code for reading the reference voltage. Basically this is cribbed from Geoff's source but the interesting bit is that I have been able to use the Microchip hardware library functions without any issues
#define _SUPPRESS_PLIB_WARNING
#include <plib.h>
#define FAM
#include "APIDefs.h"
long long readref(float *a){
int anChan,i;
long val=0;
CM1CON = 0b1000000000010011; uSec(1000); // turn on the internal voltage reference and let it settle
CloseADC10();
for(i=0;i<=8;i++){
anChan = ADC_CH0_POS_SAMPLEA_AN14;
SetChanADC10( ADC_CH0_NEG_SAMPLEA_NVREF | anChan );
OpenADC10( ADC_FORMAT_INTG | ADC_CLK_AUTO | ADC_AUTO_SAMPLING_ON , \
ADC_VREF_AVDD_AVSS | ADC_OFFSET_CAL_DISABLE | ADC_SCAN_OFF | ADC_SAMPLES_PER_INT_1| ADC_ALT_BUF_ON | ADC_ALT_INPUT_ON , \
ADC_CONV_CLK_INTERNAL_RC | ADC_SAMPLE_TIME_15 , \
0 /* anInput */ , \
SKIP_SCAN_ALL \
EnableADC10(); // Enable the ADC
while ( ! mAD1GetIntFlag()) ;
val+= ReadADC10(0); // read the result of the conversion
if(i==0)val=0; //scrap the first reading
mAD1ClearIntFlag();
uSec(1000);
CloseADC10(); // turn off the ADC so that it does not add to the power drain (particularly in sleep)
CM1CON = 0; // turn off the internal voltage reference (in case pin = 0)
*a=FDiv(M_ANY(0x453A2E8C),IntToFloat(val)); //0x453A2E8C = 1.2 * 8192 / 3.3
return val>>3; //divide by 8
Edited by matherp 2015-06-16
MolsonB
Posted: 05:10pm 01 Jul 2015
With scalefactor as a float, I am getting the error.
  Quote  Error: Argument cannot be floating point
Changed it to a integer, and this error.
  Quote  CPU exception #6 (bus error on ifetch) at address 0x46454420
I'm on 4.6B, not sure if that matters?
MkII 44pin - v5.0
ColorMax 2 - v4.5
Posted: 08:43pm 01 Jul 2015
  Quote  I'm on 4.6B, not sure if that matters?
This code only works on 4.7 (only use beta 8 until Geoff releases something later than b11). The normal pin(0) still works in 4.6bEdited by matherp 2015-07-03
MolsonB
Posted: 05:02am 02 Jul 2015
Oh ok that makes sense. I was waiting to upgrade to 4.7 when it comes officially released. I'll play around with pin(0) until then.
MkII 44pin - v5.0
ColorMax 2 - v4.5
