Local Time 14:39 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Analog Clock (Sample Code)[MMBasic]
Yourock17
Posted: 12:22am 05 Jun 2015
Hello, I have made an analog clock that features:
-A Wake-Up Alarm, That doesn't sound on weekends :D
-Second, Minute and Hour hands.
-AM/PM Support
Made For
Monochrome Maximite
Firmware Ver: 3.0203
Horizontal Res: 480
Vertical Res: 432
SetPin 1,8
Print "0=Sun, 1=Mon, 2=Tue, 3=Wed, 4=Thur, 5=Fri, 6=Sat"
Input "Enter The Day Using The Above Code (D): ", D
Input "Enter The Alarm Time: ", Alarm$
Input "Enter The Time: ", T$
Time$ = T$
Cls
Font 1,2
DRAWFACE
Seconds = Val(Right$(Time$, 2))
Minutes = Val(Mid$(Time$, 4,2))
Hours = Val(Left$(Time$, 2))
If Hours > 12 Then
PM$ = "Yes"
Else
PM$ = "No"
If Time$ = "00:00:00" Then
D = D+1
D = D Mod 7
If Time$ = Alarm$ Then ALARM
Hours = Hours*5+(Minutes/12)
Minutes = Minutes+(Seconds/60)
'Second Hand
SDegrees = (60-(Seconds+30))*0.10467
XS = 240+200*Sin(SDegrees)
YS = 210+200*Cos(SDegrees)
'Minute Hand
MDegrees = (60-(Minutes+30))*0.10467
XM = 240+180*Sin(MDegrees)
YM = 210+180*Cos(MDegrees)
'Hour Hand
HDegrees = (60-(Hours+30))*0.10467
XH = 240+100*Sin(HDegrees)
YH = 210+100*Cos(HDegrees)
'Drawing The Hands
Cls
DRAWFACE
Print@(240,240) "PM:" PM$
Line(240,210)-(XS,YS),1
Line(240,210)-(XM,YM),1
Line(240,210)-(XH,YH),1
Pause 1000
'Drawing The Face
Sub DRAWFACE
Num = 0
Num = Num+1
Digit = Num Mod 5
FaceDeg = (60-(Num+30))*0.10467
OX = 240+210*Sin(FaceDeg)
OY = 210+210*Cos(FaceDeg)
IX = 240+205*Sin(FaceDeg)
IY = 210+205*Cos(FaceDeg)
Line(IX,IY)-(OX,OY),1
If Digit = 0 Then Print@((OX-15),(OY-5)) (Num/5)
Loop Until Num > 59
'Alarm
Sub ALARM
If D = 0 Or D = 6 Then GoTo 3
Cls
Decider = Fix(Rnd*4)
If Decider = 0 Then Print@(200,200) "Time To Get Up"
If Decider = 1 Then Print@(200,200) "Wake Up Sweetie"
If Decider = 2 Then Print@(200,200) "Mornin' Sunshine"
If Decider = 3 Then Print@(200,200) "Just Get Up"
If Decider = 4 Then Print@(200,200) "Helllooooo"
If Decider = 5 Then Print@(200,200) "Cmon, Get Up"
If Alarm$ = "07:00:00" Then Print@(200,200) "Its Just School :( "
If Hour < 7 And TOD$ = "AM" Then Print@(200,200) "Its A Bit Early! "
If D = 5 Then Print@(200,200) "Whoo, Its Friday! "
Print@(100,300) "Press <Space> to stop!"
K$ = ""
Pin(1)=1
Pause 200
Pin(1)=0
Pause 100
Pin(1)=1
Pause 200
Pin(1)=0
Pause 500
K$ = UCase$(Inkey$)
Looped = Looped + 1
TimeRem = 180-Looped
Min = Fix(TimeRem/60)
Sec = TimeRem Mod 60
Font 1
Print@(50,350) "Or Alarm Will Stop In: " Min " Minutes and " Sec " Seconds"
Loop Until K$ = Chr$(32) Or Looped = 600
Cls
3 Font 2
I am really proud of this as I have recently learnt trigonometry. Thank you. Also could anyone give hints as to how to fix the flashing :)Edited by Yourock17 2015-06-06
BobD
Posted: 02:04am 05 Jun 2015
Kye
You have done well to post your versions of hardware and software. The version of MMBasic has moved on substantially since your chip was loaded. Version 4.5 is the latest. You should consider updating. You can get the latest MMBasic on this page http://geoffg.net/maximite.html and this link will take you straight to the download http://geoffg.net/Downloads/Maximite/Maximite_MMBasic.zip. You should find new firmware, support programs and manuals in that ZIP.
This program is good practice for your trig. Sorry I can't help with the flashing. You may have to give a bit more info.
Hint: put square brackets around your smiley or use the sidebar. You'll get a graphic then. Click more... under the smilies in the sidebar.
Bob
Yourock17
Posted: 02:43am 05 Jun 2015
Thanks Bob for the tips, I have never attempted updating and probably should. I also forgot to mention in the post that there is a Piezo Buzzer attacted to Pin 1. Damn it does it's job with the Buzzer.
mbramwel
Posted: 10:06am 05 Jun 2015
I do not have a maximite setup to test this.
Some comments based on reading the code:
You are clearing the screen and then rewriting the entire screen contents.
Consider not doing this.
Instead, perhaps you should clear just where where the text is written and write new text on the screen.
For the hands, write the old hands first with the color set to the background color, this causes them to disappear.
Then write the new hands using the foreground color.
This means only the hands are rewritten and the flashing would not be noticeable.
In practice it means you have a first-run routine that draws any text boxes and related non-changing screen items.
You would have a screen refresh routine that runs once a second that updates the screen by erasing text, write new text; erase hands, write new hands.
