Local Time 14:39 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2 multiple UI question
dasyar
Posted: 08:07am 02 Jun 2015
I still have my MM on a breadboard with an XBee module attached (com2) and com1 hooked to the Raspberry Pi /dev/ttyAMA0 port. With the program below I can turn on/off the LED via an XBee login, but how do I add a com1 login that also responds to the do ... loop UI?
Basically I would like to be able too login from an XBee or the RPi and have a UI session, respond to the commands. Is there some way of doing 'INPUT #1 AND INPUT #2,dat$' or maybe a separate loop that checks to see if there are chars waiting in the #1 or #2 buffer, then proceeding to the main loop? Or maybe there is a better way to do this?
My next step, add a DHT22 module and be able to data log it to file on the RPi, if that is possible.
' Test1.bas
Open "COM2:9600" As #1 ' -> XBee
Pause 2000
Open "COM1:115200" As #2 ' -> /dev/ttyAMA0 (Raspberry Pi)
SetPin 15, dout
Print #1,"Test1 program"
'Main loop
Print #1, ">" ' XBee
Input #1,dat$ ' XBee
If dat$ = "quit" Then Exit
If dat$ = "onled" Then onLED
If dat$ = "offled" Then offLED
' Print #1,Chr$(10) 'LF ?
' Print #1,Chr$(13) 'CR ?
Close #1
Close #2
sub onLED
pin(15) = 1
end sub
sub offLED
pin(15) = 0
end sub
jman
Posted: 09:24am 02 Jun 2015
Hi
You could use the LOC command to check if the buffers had any content
from the manual
LOC( [#]fnbr )
"For a serial communications port opened as 'fnbr' this function will return the
number of bytes received and waiting in the receive buffer to be read.
The # is optional"
Jman
dasyar
Posted: 09:11am 03 Jun 2015
Out of curiosity, there is a line of example code , in the manual:
[code]
A$ = INPUT$(1, #1) : B$ = INPUT$(1, #1)
[/code]
What does the ':' in between the two statements do? Also in the manual, the INPUT command explanation does not show what an INPUT with '()' is supposed to accomplish, maybe for the experts it is obvious, for me, it is not. So what is the '1', in the parenthesis doing.
Chris Roper
Posted: 09:45am 03 Jun 2015
  dasyar said   Out of curiosity, there is a line of example code , in the manual:
[code]
[/code]
The Colon is a command separator, it allows you to have more than one command on a line rather than one line per command.
  dasyar said   Also in the manual, the INPUT command explanation does not show what an INPUT with '()' is supposed to accomplish, maybe for the experts it is obvious, for me, it is not. So what is the '1', in the parenthesis doing.
The first 1 is saying to retrieve only a single character from the buffer, the second #1 is the handle of the port being read.
So the Line you show retrieves 2 bytes from Handle #1, the first byte is stored in A$ and the second in B$.
Hope that helps,
Chris
http://caroper.blogspot.com/
dasyar
Posted: 01:38am 04 Jun 2015
[code]
print #1, ">"
[/code]
For the 'print' command, is their some way of controlling CR associated wit it? It seems that this is wreaking havoc on my terminal screen output, I am getting a CR in places where I need better control. Also I noticed that the 'INPUT' command when used with '#', is not showing a '?', in some cases that is a good thing.
In the code snippet bellow, I was testing to see if the 'INPUT' command was actually waiting for a keypress, which it is. But I noticed my 'do ... loop' is not working as expected, it is not responding to my inner 'IF' statements. In fact when I do key in a command, I always get the "Nothing yet", with no response to my keyed in command. So it seems that the use of 'LOC' is clearing out the buffer, is that the way 'LOC' was intended to be used?
[code]
' Test1.bas
Pause 2000
SetPin 15, dout
Print #1, "Test1 program"
print #1, ">"
'Main loop
input #1,dat$
if (loc(#1) > 0) then
else
print #1, "Nothing yet"
endif
Close #1
Close #2
sub onLED
pin(15) = 1
end sub
sub offLED
pin(15) = 0
end sub
[/code]
Chris Roper
Posted: 02:09am 04 Jun 2015
  dasyar said   [code]
print #1, ">"
[/code]
Terminate the Print Argument with a ; character to suppress <CR/LF)
In Your Example:
[Code]print #1, ">";[/code]
should solve your problem.
I will have to come back to the second question when I have time to read the code :)
Chris Roper
Posted: 03:39am 04 Jun 2015
  dasyar said  In the code snippet bellow, I was testing to see if the 'INPUT' command was actually waiting for a keypress, which it is. But I noticed my 'do ... loop' is not working as expected, it is not responding to my inner 'IF' statements. In fact when I do key in a command, I always get the "Nothing yet", with no response to my keyed in command. So it seems that the use of 'LOC' is clearing out the buffer, is that the way 'LOC' was intended to be used?
[code]
'Main loop
input #1,dat$
If dat$ = "quit" Then END
else
endif
[/code]
Input is waiting for data, when you press enter the data is transferred from the buffer to dat$. So, unless you pressed enter twice, there should be nothing in the buffer and LOC will always return 0.
I don't have access to a micromite to test but this should work:
[code]
'Main loop
input #1,dat$
[/code]
Also there is no Exit defined, use END, as above, to exit the program.
if you want to use LOC then you could use it in your example like this:
[code]
'Main loop
dat$ = INPUT$(LOC(1), 1) ' Read all the characters in the input buffer
else
endif
[/code]
Chris
Edited by Chris Roper 2015-06-05
dasyar
Posted: 07:25am 04 Jun 2015
Thanks Chris, I am reading the manual, but somehow my interpretation of what I read was not working as expected. The reason I was using 'exit' is because I just wanted to break out of the do...loop, I think when you use the 'end', it actually ends the program.
The reason I am using 'loc()', is that I want to check if source #1 or #2 has any thing in the buffer and then do the main loop accordingly. I want the main loop UI to be accessible by #1 or #2, by whichever one is logged in. This is the coding structure that I am trying to get a handle on. I was trying to implement a logical operator OR to check the loc(#1) OR loc(#2), but that did not work, at least not the way I had it coded.
dasyar
Posted: 09:45am 04 Jun 2015
OK, I am using "User Manual MMBasic Ver 4.6". In there it states "The old standard of EXIT on its own(exit a do loop) is also supported." I guess my interpretation of that is not correct, in the code below? When I run the program the print stuff following the do loop is not being shown on the terminal screen. When I use 'EXIT DO', the same thing occurs. Not sure what is going on at this point.
[code]
' Test1.bas
Pause 2000
SetPin 15, dout
print #1, ">"; ' ';' is used to suppress a CR
'Main loop
INPUT #1, dat$
print #1, ">";
Print #1,Chr$(13)
print #1, "Closing PORTS and ending program."
Close #1
Close #2
end
sub onLED
pin(15) = 1
end sub
sub offLED
pin(15) = 0
end sub
[/code]
BobD
Posted: 09:55am 04 Jun 2015
dasyar
It is no longer good enough to tell us only what manual you are using. There are too many versions of hardware and software in use now, many of them Beta versions with extra capabilities. The version of firmware is more important. This can be found from your files if you know which one you last loaded or displaying the variable MM.VER in the running system.
Bob
dasyar
Posted: 10:18am 04 Jun 2015
MM.VER = 4.06, Hmm, does this mean I have some old chip(s)? Since I am new here, I guess I should ask, how often does the MM.VER change around here. I purchased my chips, probably around five months ago, and what, the MM version is up 4.6? So is there an archive for MMBasic Manuals, and I should really be reading a 4.06 manual instead? Not sure what to do next.
Posted: 12:55pm 04 Jun 2015
4.06 is V4.6 so you are not too far behind.
V4.7 is in beta.
There are also Maximites, which have slightly different syntax for some commands, so it can be difficult for others to know for sure what you are using.
dasyar
Posted: 12:20am 05 Jun 2015
CGMICROMITE2 - Micromite MkII
Maximite computer on a chip - single DIP microcontroller.
This is a 28 pin chip that I have implemented on the breadboard. And I am using TeraTerm as the program to log into the chip via XBee module. To tell the truth, I did not think that such a small little program, which I have shown a couple posts back, would be giving me so much trouble, or at least working as expected.
